HighBeam LED indicator stays 'on'
The current through the low beam filament will go to ground through the common connection between the low beam filament and the high beam filament. Once there it won't back up and energize the high beam filament to give you the spurious high-beam indication. Getting to ground is the goal of every electrical current.
Where does the other side of the LED connect?
Phil Woolfson
09-04-2018 09:54 AM
