Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Changing Transmission Fluid.
Old Oct 10, 2013 | 02:19 PM
slo5oh88's Avatar
slo5oh88
I have a 2005 Escape 4cyl 2WD. 135K Miles
The tranny has started shifting a little hard and the fluid is on the low end of normal on the dip stick.
I want to change the tranny fluid can someone provide me the steps? I just have little auto tranny experience.
Is it as simple as dropping the pan let fluid drain then put pan on and fill with fluid?
Thanks in advance.
Old Oct 10, 2013 | 03:58 PM
projectSHO89's Avatar
projectSHO89
Drain and fill (3x)
There's a drain plug on the bottom of the transmission (no pan or filter). Drain it out, fill it back up (3-5 quarts), run the engine a minute, repeat twice more. You'll end up with about 3/4 new fluid.
or
Pump and dump
Disconnect return line from cooler and point into 5 gallon bucket. Run engine at idle until air starts to come out and cut engine. Refill transmission. Repeat once. Reconnect line and check fluid level.
Old Oct 11, 2013 | 07:36 AM
jas88's Avatar
jas88
Personally I just do the drain and refill every other oil change. It takes about 4 qts.
Old Oct 14, 2013 | 08:13 AM
tomw's Avatar
tomw
If you drive onto some ramps for clearance, and remove the plug, be prepared to catch 6 quarts. If you drain it cold, you'll get more fluid to replace. Capacity per manual is 10.2 quarts. If the fluid is not in bad condition, i.e., smelly and burned/black, changing 60% a few times will be pretty good preventive maintenance.
tom
kevin.ford-trucks
Jun 16, 2012 01:31 PM
orygunf150
2004 - 2008 F150
Dec 31, 2009 07:16 PM
eric777
17
Aug 26, 2006 06:54 AM
teddyu
1983 - 2012 Ranger & B-Series
52
Jul 31, 2006 07:07 PM
tres01expy
May 26, 2003 10:13 PM
