Spare Wheel Weight Question
Old Oct 10, 2013 | 06:06 AM
DSN46's Avatar
DSN46
Hopefully someone knows.
I took my spare out to inspect it about a month ago. I have had the wheels off of all four corners of the Ex many times doing work on it. I have to tell you though, when I pulled that spare out I couldn't believe how heavy it was! I'm a fairly strong guy, and maybe it was the size and bulkiness of it, but I was surprised anyway. That spare seemed to weigh a lot more than the other four wheels.
Does anyone know what the difference is between the weight of the spare rim and the rims that are mounted at the four corners?
I ask because I am about to mount the spare on my homemade custom safari rack on the roof. If I can find a lighter rim to mount the spare on, it would make life and top-heaviness a lot easier!
Thank you!
James
Old Oct 10, 2013 | 09:38 AM
Mr. Crab's Avatar
Mr. Crab
Aluminum versus steel perhaps? Whatever it is, you're right; the spare is beastly heavy!
Old Oct 10, 2013 | 12:00 PM
DSN46's Avatar
DSN46
The aluminum vs. steel thing may be the culprit.
I'm just wondering how much weight I would be saving by buying a used alloy wheel and having the spare mounted on it instead of the that thing in the back right now.
Thank you.
James
Old Oct 10, 2013 | 12:24 PM
AndrewWV's Avatar
AndrewWV
Just guessing here. Looking at the tech specifications for the 2001 (there's a link in the tech folder) I see a section on payload/weight ratings for various options. I'm assuming this is the amount to add/subtract from the rated cargo capacity for various options. For "chrome styled forged aluminum" it says (-28/-55) and "premium forged aluminum" it says (-22/-44). Those weights are for front/total in pounds, and I'm guessing they must be the difference from a stock steel wheel. If I'm reading that correct, the aluminum wheels look to be about 11 to 14 pounds lighter than the steel wheels.
Old Oct 10, 2013 | 03:12 PM
DSN46's Avatar
DSN46
Thank you! I will take a look at those numbers.
I guess the "real" way to do it when I get the chance is to remove a tire from the one of the corners.... stand on a scale while holding it, then do the same with the spare. But WOW what a PIA that will be!
Thanks again.
James
Old Oct 10, 2013 | 05:36 PM
Misky6.0's Avatar
Misky6.0
Thank you!
James
Old school idea:
Get a short length of pipe to use as the pivot point, take a 6-8 ft board lay it over the pipe.
Put one tire on each side.
One gallon of water is 8.2 lbs.
Borrow kitchen measuring
Cups and a couple old milk jugs...
Maybe involve your child(ren) and those next door and have a science project.
Then use a bathroom scale to see how you did..
Old Oct 10, 2013 | 06:25 PM
DSN46's Avatar
DSN46
Originally Posted by Misky6.0
Old school idea:
That is an awesome idea! Might as well make something useful out of it while having to do it anyway. Also, we homeschool our kids and wouldn't you know it, our 12 year old is on a chapter in Science dealing with mechanics.... use of fulcrums and boards, pulleys and such.
Thanks for the idea.
James
Old Oct 10, 2013 | 07:37 PM
LivingLarge's Avatar
LivingLarge
Thank you!
James
James, try this out for a couple months you won't notice the additional 14lbs
Old Oct 10, 2013 | 07:49 PM
DSN46's Avatar
DSN46
Attachment 82287
I don't know brother... that looks like it might hurt me
I'd better stick to my free-weights.... then again, since I find it difficult to wrestle that spare out of the back... maybe I should give that thing a try!
James
Old Oct 10, 2013 | 09:10 PM
AndrewWV's Avatar
AndrewWV
James
Cool! Nice to meet another homeschooler on the forum.
WestCoastTodd
Dec 31, 2010 06:42 PM
Pele
Aug 17, 2008 03:34 AM
workinman
2004 - 2008 F150
Jan 9, 2008 01:18 PM
N7ghtwolf
Jul 29, 2007 12:50 PM
Nicks91Explorer
Jul 21, 2004 05:04 PM
