another glow plug thread...
Old Oct 13, 2013 | 07:47 PM
lindstromjd's Avatar
lindstromjd
Originally Posted by Zagg77
Guys, it appears I may have spoken too soon... The WTS light clicks on, light stays on for 15-20seconds, but as soon as it goes off there is a random clicking... Ideas???
*Just a note, if I start the truck after WTS light goes out, it fires immediately, but I want to address a bad relay or anything else before it lets me sit.
It's completely normal behavior. It's the controller after-glowing the glow plugs. They can still be heating up for 1-2 minutes after you start the engine.
Old Oct 14, 2013 | 09:19 AM
RA31925's Avatar
RA31925
Originally Posted by MPoulson
Sounds like the normal after glow clicking that they do.
Yep. My 94 does the same exact thing.
Old Oct 14, 2013 | 03:17 PM
Zagg77's Avatar
Zagg77
Great, that eases my mind a lot... This is my first diesel (can you tell?) so there are some things... okay, so there are a lot of things I am not familiar with. Thanks!
Old Oct 15, 2013 | 07:02 PM
Zagg77's Avatar
Zagg77
Just an edit to the random pattern clicking... I was looking for vacuum leaks in the engine compartment last night and found that I had either forgotten to connect or accidentally disconnected a glow plug wire... Also, the PO had hot wires exposed under the rear seat for an amplifier (scared the **** outta me when it touched the seat belt buckle!!!) Disconnected the amp power lead to the battery and I'm seeing less amp fluctuations and clicking after WTS light goes off. Thanks for all your help!
brokeasajoke
Dec 10, 2013 04:56 PM
dieselaholic
Dec 1, 2011 07:30 AM
damac
Dec 20, 2009 10:02 PM
97biostroke
Feb 8, 2009 01:51 PM
michaelbrainardatwor
Jan 4, 2008 07:29 PM
