another glow plug thread...
Old Oct 10, 2013 | 01:01 AM
Zagg77's Avatar
Zagg77
Hey guys, I promise this thread is not to ask if it's okay to use Autolites!!!
I am replacing gp's and since I am a gp virgin, I decided to go with the driver side front to get my feet wet... Blew out with air, hit it with some PB, and unscrewed it. I am using ZD-9s to replace them.
My question is: I screwed it in as tight as seemed safe, but there are still threads showing... Is this normal? It doesn't seem to be in quite as deep as the old one next to it, but I'm afraid torquing it any more will break it. Any advice/experience is appreciated.
Old Oct 10, 2013 | 01:28 AM
zloetakoe's Avatar
zloetakoe
If it's snug, it's snug. Wouldn't worry too much about it. As long as you are starting the threads by hand so as not to strip it out and you have some torque, they should stay there just fine. Certainly wouldn't overtorque (break em) just because they "appear" to have a few more threads sticking out, that won't hurt anything.
Good call on not using the autolites!
Old Oct 10, 2013 | 07:42 AM
lindstromjd's Avatar
lindstromjd
X2 ^^^^^^
What he said.
Old Oct 10, 2013 | 08:56 AM
RA31925's Avatar
RA31925
I highly recommend you put anti-seize on the glow plugs threads. And the torque spec for IDI glow plugs is 12 ft-lb (144 in-lb).
Old Oct 10, 2013 | 11:07 AM
Zagg77's Avatar
Zagg77
Great! Thanks guys! One more thing... I was working on this last night at midnight - probably in the 50s... Would this be easier if the block was warm?
Old Oct 10, 2013 | 11:10 AM
Zagg77's Avatar
Zagg77
Copy on the Anit-Sieze... Picked it up today.
Old Oct 10, 2013 | 11:26 AM
RA31925's Avatar
RA31925
It's best if the heads and plugs are the same temperature, but it probably won't make a huge difference either way.
Old Oct 10, 2013 | 12:46 PM
Zagg77's Avatar
Zagg77
Okay, thanks. Got 5 done. Working my way under the turbo. Not sure what the deal was with that first one - I backed it out and put anti-sieze on it and turned it back in - looked fine. There was a little bit of engine gunk on it... May have hung it up a bit. Good now!
Old Oct 10, 2013 | 12:51 PM
Zagg77's Avatar
Zagg77
Yeah, couldn't warm it up anyway... wouldn't start.
This all started with the on then right away off glow plug light followed by clicking every 1 second (cycling). Ohm tested the plugs and was gettin' no reading. 0.0. If it's not the plugs I'll be heading to the relay and controller!
I read the posts regarding glow plugs so I'm hoping I can answer most of my own questions, but I really appreciate all the advice. Thanks!
Old Oct 10, 2013 | 01:35 PM
zloetakoe's Avatar
zloetakoe
I took mine all out and tested them using a battery starter. Easy way to see if they REALLY work. Was hard to tell sometimes with the voltmeter.
Old Oct 11, 2013 | 06:37 PM
Zagg77's Avatar
Zagg77
Thanks for the tip. I got 'em all out and replaced... They were Beru's previously and came out fine except for that one under the turbo - what a b!@ch!!! Luckily there were plenty of you out there that figured out the "Fuel Hose Trick" so I tried it and it worked like a charm. Worked well to get that one started too.
The WTS light came on for 15 seconds or so, no repeated clicking, truck fired up right away and has started up normally 3 times since. Thanks to all of you who post your tricks, tips and pics!!!
Old Oct 12, 2013 | 04:51 PM
Zagg77's Avatar
Zagg77
Guys, it appears I may have spoken too soon... The WTS light clicks on, light stays on for 15-20seconds, but as soon as it goes off there is a random clicking... Ideas???
*Just a note, if I start the truck after WTS light goes out, it fires immediately, but I want to address a bad relay or anything else before it lets me sit.
Old Oct 12, 2013 | 06:37 PM
MPoulson's Avatar
MPoulson
Sounds like the normal after glow clicking that they do.
Old Oct 12, 2013 | 08:51 PM
Johnny L's Avatar
Johnny L
The best way i know to test glow plugs is to use a current clamp around each lead when gp should be on. If its getting 20-25 amps that is ironclad proof the gp works and is also getting power from the system.
Old Oct 13, 2013 | 07:41 PM
Zagg77's Avatar
Zagg77
Okay, thanks! I'm sure the GP's are working - just didn't want to overlook another issue.
