Going in deep!!!!
Old Oct 9, 2013 | 09:51 PM
Deep South's Avatar
Deep South
Going in deep!!!!
Its that time gentlemen. Oil cooler has s**t the bed and while im in there changing the oil cooler i have new dummy plugs, standpipes, blue spring kit, egr delete and fumoto valves. Went to local international dealership and got some restore and restore plus and some fleetrite ec-1 rated elc coolant. Already did my flush and will begin teardown in the morning. Any helpful advice for easier removal and/or installation is always greatly appreciated. Thanks in advance and wish me luck.
Old Oct 9, 2013 | 09:59 PM
BLADE35's Avatar
BLADE35
OIL COOLER REBUILD INFO
TURBO REMOVVAL
https://www.ford-trucks.com/ford-man...%20Removal.pdf
INTAKE MANAFOLD REMOVAL
https://www.ford-trucks.com/ford-man...%20removal.pdf
OIL COOLER REMOVAL
https://www.ford-trucks.com/ford-man...er_Removal.pdf
OIL COOLER NAVSTAR
https://www.ford-trucks.com/ford-man...20Navistar.pdf
OIL COOLER REPAIR
https://www.ford-trucks.com/ford-man...r%20Repair.pdf
Old Oct 9, 2013 | 10:02 PM
BLADE35's Avatar
BLADE35
Suck the valley out where the Oil Cooler sits DO NOT wipe with rags or paper towels
very important to keep the HPO Reservoir Free of Lint and Junk
Best to suck oil out and leave it at that I have an Old Shop Vac I use for that stuff
Old Oct 9, 2013 | 10:07 PM
Deep South's Avatar
Deep South
Thanks for the links and the info Blade.
Old Oct 9, 2013 | 10:15 PM
BLADE35's Avatar
BLADE35
No Problem
If you get in a Bind Lots of Folks here have done it so you will have Lots of Help
What type EGR Deleate did you go with ??? I used the one that removes the Cooler and the Intake was easier to install Back
In fact I put the Intake back in then Installed the Intake gaskets after so I didn't Kill the New Intake gaskets. You will see what I mean with the WIre Harness in the Way
Old Oct 10, 2013 | 09:44 AM
Deep South's Avatar
Deep South
I went with the sinister egr delete. Good price and has good reviews to go with it. Was going*to go with the bulletproof egr but decided to just do away with the whole thing. And yess the wiring harness is a pain
Justus6.0L
Apr 4, 2018 09:06 AM
landshark69
Apr 10, 2014 01:46 AM
Talyn
28
Apr 6, 2013 08:32 AM
jakesfj40
Dec 19, 2010 07:45 PM
hotweekend
Nov 23, 2010 11:00 AM
