Sponsored by: Real Truck
PCV Valve location
Old Oct 9, 2013 | 09:36 PM
cyclone3565's Avatar
cyclone3565
PCV Valve location
I also posted this in the F-150 forum. I was not sure where to post it. My apologies.
I just bought a 2008 F-250 with the 5.4l engine. The engine had been replaced, the date on the engine sticker is 4-21-06. I am trying to figure out where the PCV valve is located. It is not in the location that the 06 is, the blue valve on the passenger side valve cover. Dealership tells me I have to replace the entire valve cover, which also does not make sense. If anyone can help me that would be great. If possible I could also use a partnumber and where it is available.
Thanks in advance
Old Oct 9, 2013 | 09:52 PM
dkf's Avatar
dkf
On the 3V 6.8ls the PCV valve is built into the valve cover so it would not surprise me in the least if the 3V 5.4l is the same.
Old Oct 9, 2013 | 10:04 PM
cyclone3565
That's what the dealer said....How do you then service it/replace it. I am old school, replace every 50,000 or 100,000 miles, or at the very least check it and clean it.
Old Oct 9, 2013 | 11:14 PM
Hotpocket's Avatar
Hotpocket
on the 2v you just twist it counter clockwise and pull it out, not sure about the 3v
Old Oct 10, 2013 | 08:45 AM
dkf's Avatar
dkf
Valve cover has to be replaced as an assembly. Unless oil consumption spikes I would just run it. A new valve cover/PCV valve assembly is going to cost north of $200.
sls1
Feb 4, 2019 10:52 PM
cyclone3565
2004 - 2008 F150
Oct 14, 2013 02:09 PM
pappy19
Modular V10 (6.8l)
Aug 25, 2012 03:11 PM
DernMooseAk
Modular V10 (6.8l)
15
Jun 21, 2012 12:37 PM
randy6800
1983 - 2012 Ranger & B-Series
Mar 13, 2008 07:06 PM
