Stock EGT sensor??
Old Oct 8, 2013 | 09:23 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Stock EGT sensor??
Pulling my motor i noticed a wire/tune going into the passenger side exhaust manifold and leading to a sensor attatched to the HPOP. What is it?
Ford4Life7.3
My buddy says its a EGT sensor, and although ive never heard it mentioned or that it exists, its about the only logical thing. Sure as hell aint an 02 sensor lol!!
Old Oct 8, 2013 | 09:27 PM
fordpride's Avatar
fordpride
Can you get a pic ?
Whatever it is it isn't stock
Old Oct 8, 2013 | 09:30 PM
Ford4Life7.3
Will do, gimme a sec
Old Oct 8, 2013 | 09:35 PM
ReBilld's Avatar
ReBilld
It's not something on the Cali models is it?
Old Oct 8, 2013 | 09:38 PM
Ford4Life7.3
Its a metal tube that goes to that sensor
Old Oct 8, 2013 | 09:39 PM
Ford4Life7.3
And my truck is not a cali model
Old Oct 8, 2013 | 09:40 PM
Ford4Life7.3
This same thing was also on my buddies 95 CC/DRW, CA model. Mine is not. But his other 95 also has it and is not a CA model
Old Oct 8, 2013 | 10:03 PM
fordpride's Avatar
fordpride
That's the exhaust back pressure sensor
Old Oct 8, 2013 | 10:05 PM
ReBilld's Avatar
ReBilld
X2^^^^^^^^
Old Oct 9, 2013 | 08:03 PM
Mike Hannahs's Avatar
Mike Hannahs
Yep thats the exhaust back pressure sensor and tube,take the tube off and clean it sometime it will help a bit with mpgs and performance, i was shown that and i did it and it made a difference, i was told to clean it with a cable like you see on pedal bikes used for brakes and i was told to push it in there and run it with a drill which worked good but it was tough to get in the tube since it was full of carbon, i used wd-40 to help with that and ran it for a few a couple of times and got it all cleaned up then i cleaned the wd out with brake cleaner i didnt know if i needed to but i did.
Old Oct 9, 2013 | 08:04 PM
Mike Hannahs
The sensor may need cleaned out to, mine sure did
Old Oct 9, 2013 | 09:36 PM
Ford4Life7.3
When i got the truck the wires for the sensor were cut out of the harness...so i take it it doesn't matter if i clean it or not lol?
Old Oct 9, 2013 | 10:00 PM
Mike Hannahs
Hahaha on that one i dont know, i bet if it was hooked up and working good it would sure make it run better but im not sure, i wouldn't think it would matter with it cut i wonder why they cut those wires, maybe there is something i dont know about that cutting the wires does hahaha but i doubt it, maybe someone else may pick this one up and fill us both in on that hahah, i do know with mine unplugged it made my truck throw a (CEL) Check Engine Light.
Old Oct 9, 2013 | 10:06 PM
Ford4Life7.3
As a matter of fact a lot of random things were cut out or broken off, but its always ran fine and never thrown a CEL
