Stock EGT sensor??
Old Oct 9, 2013 | 10:17 PM
Mike Hannahs's Avatar
Mike Hannahs
Originally Posted by Ford4Life7.3
As a matter of fact a lot of random things were cut out or broken off, but its always ran fine and never thrown a CEL
Very odd hahaha good thing it runs at least and runs good
Old Oct 9, 2013 | 10:23 PM
Ford4Life7.3's Avatar
Ford4Life7.3
That sensor, the EBPV sensor is deleted (I did that when i deleted the valve) , and i think another was broken off so when I rebuilt the wiring harness.
Old Oct 9, 2013 | 10:34 PM
Mike Hannahs
This weekend im going to gut my EBPV i need to find out what tool is used to take those star looking bolts off though and i herd you have to put new ones in because the old ones will back off once re tightened but im not sure on that,you wouldn't happen to know what size and type of tool i would need for that would you? and any thing on the new bolt thing? i can get some new ones but i dont see how the old ones wouldn't work
Old Oct 9, 2013 | 10:40 PM
Ford4Life7.3
Its a 12pt 8MM socket, nothing special. And i reused the old bolts, not problems. They were tight as ever the other day when i started tearing down my turbo for a rebuild.
Old Oct 9, 2013 | 10:42 PM
Ford4Life7.3
Just a tip, use a NPT plug when you plug the actuator hole. And dont use thread tape as it wont hold up to the heat, use the liquid thread locker. I did and no issues with leaks.
Old Oct 9, 2013 | 10:43 PM
Mike Hannahs
Nice, thats good to know, thanks a bunch, i hope you have a good night and all im getting off here now i got to get up for work in the morning so untill next time and thanks for the help
Old Oct 9, 2013 | 10:47 PM
Ford4Life7.3
No problem man. Good luck with your projects lol.
Old Oct 9, 2013 | 10:54 PM
Mike Hannahs
Thanks, and the same to you
spikedog
Aug 28, 2017 11:19 PM
rattleNsmoke
Jan 26, 2012 08:13 AM
TTFord07
Mar 20, 2008 07:28 PM
ron's power stroke
Oct 6, 2006 09:37 PM
dsheleg
Feb 17, 2005 09:20 PM
