Which sensor?
Old Jan 25, 2012 | 08:04 AM
rattleNsmoke's Avatar
rattleNsmoke
Which sensor?
Upon doing the R&R on my FICM, I noticed a sensor that is bolted to the front FICM bracket, and connects to a stainless steel tube that runs into the L\S exhaust manifold. Which sensor is this? Is it worth replacing since it's easy to do at this point?
Mike
Old Jan 25, 2012 | 08:33 AM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
That sensor is the exhaust backpressure sensor. As far as replacing it, mine is out and fixing to be replaced but the way I found out was on my scanguage 2 the exhaust backpressure reading was half what the baro and map pressure read at key on engine off, these 3 should all read the same within .5. Hope that helps.
Old Jan 25, 2012 | 09:10 AM
rattleNsmoke
Thanks for the reply. I have the FICM out andwith the bracketry and airbox removed it's a clean shot to the sensor now. I won't be able to use ScanGauge like you did until I restart the engine after I reinstall all that crap. Is that sensor a high failure item, and does it make sense to replace it now?
Mike
Old Jan 25, 2012 | 04:04 PM
rattleNsmoke
pop...bueller, bueller, anyone?
Old Jan 25, 2012 | 04:07 PM
npccpartsman's Avatar
npccpartsman
It's not a high failure item but they do have a higher failure rate than the CPS sensors. I'd only replace it "on demand".
Old Jan 25, 2012 | 05:32 PM
critterf1's Avatar
critterf1
X2, spendy lil' biotch.
Old Jan 25, 2012 | 07:05 PM
Jimbob8's Avatar
Jimbob8
I would clean it, tube & fitting. I used brake cleaner, Q-tips & a wire. Don't poke into sensor too far.
Old Jan 25, 2012 | 08:43 PM
BLADE35's Avatar
BLADE35
Mike
You Dont Check it with the engine running
Check it at KOEO=Key On Engine Off
You dont even need the FICM in to check it the EBP just needs to be pluged up to the wire harnesss
Now you will set a CEL if you turn the KEY ON with the FICM out but thats no Biggie should turn off when you get it back in
I would check it B4 I would replace it
Old Jan 26, 2012 | 08:13 AM
rattleNsmoke
Thanks for the input guys!
Mike
SGorman13
13
Feb 14, 2014 03:33 PM
natew
Jan 16, 2010 09:47 AM
ron's power stroke
Oct 6, 2006 09:37 PM
oldbird1965
Jun 12, 2006 12:53 PM
dsheleg
Feb 17, 2005 09:20 PM
