propane injection?
Old Oct 19, 2013 | 10:50 PM
79sparky's Avatar
79sparky
yeah oneI havesometoneto hasn'tonthe committer Iwannalook at new kits to see what they all include. yeah I've been wanting to do this for a while finally getting around to it.
Old Oct 21, 2013 | 01:29 AM
speedwrench72's Avatar
speedwrench72
LPG engines run on the liquid lpg, not vapor, your BBQ runs on vapor, the forklift's you see running around run on liquid lpg, most tanks have exits for both. the regulators are specific to fuel type. Metering systems for delivery are set up for specific requirement's think about your lpg tank as if it were a tank of air, if you remove ten lbs of vapor pressure thru a regulator it will deplete the pressure quickly as propane replaces the pressure slowly as it has to boil off to turn to a gas. in order to boil it must reach its boiling point. -50*F so the tank cools, thus the pressure drops as the vapor already in the tank cools, this is why the ice forms on the tank when you use your big propane burner to boil water for crab..if you use liquid from bottom of the tank the pressure in the tank drops only a tiny bit, and the lpg expands and boils in the metering system, not the tank, my .02
Old Oct 21, 2013 | 11:33 PM
88 Ford IDI's Avatar
88 Ford IDI
You are talking about what I mentioned earlier correct? Like the metering device that converts it to gas at the same time?
Old Oct 21, 2013 | 11:52 PM
speedwrench72
yes.. can be tricky so be carful study other systems for safety and performance, remember if the engine make more power it makes more heat. more power is more load on piston rings and higher EGT'S, TO HIGH WILL MELT HER DOWN, to help control egt's look into water injection...
Old Oct 22, 2013 | 09:48 PM
banks7.3's Avatar
banks7.3
this is the kit I am running on my motor. the kit was available from TS Performance.
I am not sure if it is still available. all parts can be purchased separate.
Beam T60 T50 Two Stage Propane Regulator
here is a link to the installation manual
www.tsperformance.com/Download/agripower/TSPPS.pdf
I am running a forklift tank mounted with the brackets off of a forklift. I have no problem smoking the tires from a rolling start (no brake stand required) on a 9000 lb plus truck. I pull a fifth wheel up the mountains from 700' elevation to 6500' elevation, without propane it will use 3/4 tank of diesel up, with propane it uses 1/4 tank up the hill.
I do have to shut the propane down on the longer grade over 5 miles at 6% plus, due to the egt's getting to high.
Old Oct 22, 2013 | 09:51 PM
banks7.3's Avatar
banks7.3
looks like the kit is still available
http://www.tsperformance.com/LPG.html
c mobley
Sep 7, 2014 09:13 PM
quality1construction
13
Jan 18, 2012 03:20 PM
eric777
31
Feb 5, 2011 10:00 PM
rolltide3006
Jun 28, 2010 03:57 PM
GUelkman375
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jul 17, 2007 03:03 PM
