General Diesel Discussion
OIL Pressure
Old Oct 8, 2013 | 03:48 PM
ballast's Avatar
ballast
OIL Pressure
Hi Guys
Technically speaking, what will happen to an engine when the
oil pressure is high ?
(higher then the pressure the engine was designed for)
What parts can be damaged and how they get damaged ?
Thanks in advance
Old Oct 8, 2013 | 07:10 PM
blueeyedfordguy's Avatar
blueeyedfordguy
Normally when the oil pressure is too high it should open up the oil pressure relief valve at a set maximum oil pressure. I am curious why you are asking
Old Oct 9, 2013 | 05:02 PM
ballast's Avatar
ballast
If low oil pressure causes engine parts to have poor lubrication and this leads to the parts touching each other and ends it with a seized engine, what would a high oil pressure do ? assuming the pressure relief valve didn't open/work
Old Oct 10, 2013 | 08:29 AM
therifleman556's Avatar
therifleman556
Depending on the engine; leaking seals, oil bypassing the turbo seals into the intake...
Im also curious, why?
Old Oct 10, 2013 | 10:36 AM
ballast's Avatar
ballast
I have always heard of low oil pressure and where that leads to but never heard any one mentioning high oil pressure, that's why i am asking
Old Oct 10, 2013 | 10:38 AM
ballast's Avatar
ballast
Some details about the seals would be great, which seals are we talking about here ?
Old Oct 10, 2013 | 12:16 PM
therifleman556
I think turbo seals would be most likely, but who knows what their limit is.
Old Oct 10, 2013 | 01:56 PM
blueeyedfordguy
Good question to ask but it depends on the engine. Some will take more abuse than others. Sometimes if oil pressure is maxed out hitting the relief valve 100% of the time it can be hard on seals. Remember, oil pressure is not created by the pump the pump only creates flow. Pressure is made from tight spaces such as main bearing clearances, and other parts that have to be with in a spec.
menzfamfour
Jul 7, 2007 03:33 AM
kitsapcountychopper
15
Apr 28, 2004 11:47 PM
