1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
So what's the dumbest thing
Old 10-08-2013, 11:15 AM
carrcreekcaller's Avatar
carrcreekcaller
carrcreekcaller is offline
you've done on your psd that you will admit to?
I just replaced the clutch master cylinder, many would say that not getting the pre-bled assembly was my first mistake. It actually wasn't that bad to bleed, with 2 guys. One on top to add fluid, and one on the bottom to remove the roll pin and line from the slave cylinder. Remove the rubber diaphragm from the reservoir and let the line gravity fill full of fluid, shove the line back in the slave, roll pin back in place, work the slave in and out (keep the slave compressed a few seconds on each stroke), replace the slave when the guy up top sees no more air bubbles, work the clutch pedal 20-30 times to remove last bit of air, and put the rubber diaphragm back in the reservoir. Just one piece of advice if you don't remove the rubber insert from the fluid reservoir, it won't matter how much pumping you do, you will never get it bled
ccc
Old 10-08-2013, 03:18 PM
atomicglock's Avatar
atomicglock
atomicglock is offline
I bought it. Biggest mistake I ever made.
That's sure to stir a turd.
Old 10-08-2013, 03:39 PM
Army RET's Avatar
Army RET
Army RET is offline
I'm waiting for the first to admit pumping gasoline into the tank. It happens!
Old 10-08-2013, 09:19 PM
PSDlongbox's Avatar
PSDlongbox
PSDlongbox is offline
buying a super cab instead of a crew cab
Old 10-08-2013, 09:23 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
Yep my mom did it last year at a Amoco, they have the gas pumps with the green handles too and she just assumed green meant diesel...
Old 10-09-2013, 11:10 AM
scotttahoe's Avatar
scotttahoe
scotttahoe is offline
Tried to find a leak in my HPOP without investigating it more. I unbolted things that should have not been and springs went flying, had to buy a new one. Turned out the oil leak was the o-rings in the Turbo Pedestal.
Moral of the story, Investigate before you dive in!
Old 10-09-2013, 04:06 PM
Shovel Monkey's Avatar
Shovel Monkey
Shovel Monkey is offline
not a PSD, but the dumbest thing I have done lately( with in the last month)...
Yanking the new tires off my old truck (97 250hd) before sending her to the dealer as a trade.
Beating the heck out of the rear tire to get it off the truck, old plow truck so its all rusty. Stopped out of breath and noticed.....
Why is there only 7 lug nuts on the ground, where did the other go??????
Yep, it was on the truck.
At that point, I sat down and quit for the day.
Old 10-09-2013, 05:52 PM
PSDlongbox's Avatar
PSDlongbox
Guilty as well Lol.
Old 10-09-2013, 06:27 PM
scotttahoe's Avatar
scotttahoe
As of now that tops it!! Got a good chuckle.
Old 10-09-2013, 07:44 PM
BobbyB's Avatar
BobbyB
BobbyB is offline
Installing a gooseneck hitch on my truck and decided to weld up an unused hole in the side brackets. Learned to never weld in old blue jeans with the crotch ripped out.......
Old 10-10-2013, 05:22 AM
Frankenbiker's Avatar
Frankenbiker
Frankenbiker is offline
Guilty!!!
I didn't realize I had a "crew" until after I bought it.....
-blaine
Old 10-10-2013, 05:46 AM
acf6's Avatar
acf6
acf6 is offline
Bought a super Duty with a 5.4...
Old 10-10-2013, 07:45 AM
Shovel Monkey
LOL..
I have done more stupid things, just not lately or out of context with a truck...
Such as laying a hammer on top of a step ladder, 3 times in a row and yes it fell on my head 3 times while moving the ladder, all in the same day....
sad thing is I do not even drink, maybe I should....
Old 10-10-2013, 08:12 AM
CarlT100's Avatar
CarlT100
CarlT100 is offline
I confess I did this years ago at a BP station. I realized my mistake after I had pumped about seven gallons. I cranked the truck just long enough enough to pull it away from the pumps. I found and empty 30 gallon drum, bought a pump and fuel filters, drained the tank, change the filters, refilled with diesel and drove away.
Old 10-10-2013, 10:41 AM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
i second this
Quick Reply: So what's the dumbest thing
