So what's the dumbest thing
you've done on your psd that you will admit to?
I just replaced the clutch master cylinder, many would say that not getting the pre-bled assembly was my first mistake. It actually wasn't that bad to bleed, with 2 guys. One on top to add fluid, and one on the bottom to remove the roll pin and line from the slave cylinder. Remove the rubber diaphragm from the reservoir and let the line gravity fill full of fluid, shove the line back in the slave, roll pin back in place, work the slave in and out (keep the slave compressed a few seconds on each stroke), replace the slave when the guy up top sees no more air bubbles, work the clutch pedal 20-30 times to remove last bit of air, and put the rubber diaphragm back in the reservoir. Just one piece of advice if you don't remove the rubber insert from the fluid reservoir, it won't matter how much pumping you do, you will never get it bled:-X15 ccc |
I bought it. Biggest mistake I ever made.:-arrgh
That's sure to stir a turd.:D |
I'm waiting for the first to admit pumping gasoline into the tank. It happens!
buying a super cab instead of a crew cab :p
Originally Posted by Army RET
(Post 13606103)
Tried to find a leak in my HPOP without investigating it more. I unbolted things that should have not been and springs went flying, had to buy a new one. Turned out the oil leak was the o-rings in the Turbo Pedestal.
Moral of the story, Investigate before you dive in! |
not a PSD, but the dumbest thing I have done lately( with in the last month)...
Yanking the new tires off my old truck (97 250hd) before sending her to the dealer as a trade. Beating the heck out of the rear tire to get it off the truck, old plow truck so its all rusty. Stopped out of breath and noticed..... Why is there only 7 lug nuts on the ground, where did the other go?????? Yep, it was on the truck. At that point, I sat down and quit for the day. |
Originally Posted by Shovel Monkey
(Post 13609822)
(Post 13609822)
Installing a gooseneck hitch on my truck and decided to weld up an unused hole in the side brackets. Learned to never weld in old blue jeans with the crotch ripped out.......
Originally Posted by PSDlongbox
(Post 13607444)
I didn't realize I had a "crew" until after I bought it..... :-huh :-banghead -blaine |
Bought a super Duty with a 5.4...
Originally Posted by scotttahoe
(Post 13610157)
As of now that tops it!! Got a good chuckle.
I have done more stupid things, just not lately or out of context with a truck... Such as laying a hammer on top of a step ladder, 3 times in a row and yes it fell on my head 3 times while moving the ladder, all in the same day.... sad thing is I do not even drink, maybe I should.... |
(Post 13606103)
Originally Posted by acf6
(Post 13611556)
i second this |
