20 inch Wheel on a 2WD?
Bolt pattern is the same so you should be fine. Only thing that might be funky is the center trim ring that goes around the front hub on the 4X4 will be wide open on the 4X2.
The larger tire diameter will goof up the 4X2's speedometer/odometer, but it'll still run fine.
-Joe
-Joe
SteveJH
09-18-2013 09:40 PM
NorthernF150
08-16-2010 10:28 PM
truckmonger1
10-15-2009 08:23 PM
