Are the 10 hole alloy wheels from a '94 F150 2 wheel drive the same as the same style wheel from a 4x4 truck or Bronco of the same vintage? I am guessing the bolt pattern is the same but what about the inner hole hub diameter and the wheel width? Thanks.
Not a guaranteed correct answer, my opinion. I would say they are. I bought a pair from some guy that scraps trucks & he pulled one off a truck that was sitting there waiting to be stripped, It was a 4wd & I have a 2wd. They fit with no problems.
They are the same. 15x7.5 with 5.5 x 5 bolt pattern.
ur trucks are almost identical in cosmetics mine is a 94 4.9 5speed 2wd s/b with 31 inch tire i shoulder of put all terrains on her though. heres a pic. how ever i was cleaning the truck and used degreaser on those rims and they seemed to faded and have some hard film like covering on them what do u recommend i do and whats the best product i want a miror shine on them and plan to put a 4" roughcountrylift for ground clearence
Now I just need to find ONE so I can have a complete set and stop running the oddball "Hurricane" steel spare wheel...
Little too far away. Got a pair w/center caps & screws for caps ( no tires ) for $50.00. Guy probably has / will have more. St. Louis area. Will try to find one here that has a picture so I'm sure were talking about the same wheel. That was quick, not a close up shot, but a couple messages back, Phone Man's picture looks like them.
Here are a coupla pics... one close up and one of the truck...
Them's the ones. Yeh, uh-huh, yepper . Can try to check with the guy Sat. fairly sure he has more. Your truck looks a lot better than mine! Wanna trade? Think my gray's a little darker ( not the primer gray measles , the gray center like yours. )
