Clutch disc issue. Pics
Old Oct 6, 2013 | 09:49 PM
73 ford guy's Avatar
73 ford guy
Wondering why my clutch disc rubs the head of flywheel bolts on the clutch disc springs??
Flywheel side. Springs shiny and flat. Rivets in centre section shiny and rubbing.
Clutch plate side
Flywheel bolts shiny and worn
Is this a dumb question? Disc wasn't backwards was it? The other side of disc would of stuck out even more.
Old Oct 6, 2013 | 09:57 PM
devino246's Avatar
devino246
This wasn't a new clutch, was it? Doesn't look like it. I'd check the flywheel thickness against spec.
Old Oct 6, 2013 | 10:09 PM
73 ford guy
I hope flywheel is within spec! My engine shop fully drill balanced it and it has about 1000 ks on it. That should of been something they checked
Wondering what the thickness specs are now..
Old Oct 6, 2013 | 10:14 PM
devino246's Avatar
devino246
You never know, unfortunately. I sent off a spindle with a press-in wheel bearing to a machine shop a couple weeks ago. Got the spindle back and they had pressed the new bearing past a circlip, crushing the seal and ruining the bearing.
Old Oct 6, 2013 | 10:22 PM
HIO Silver's Avatar
HIO Silver
Umm... where's the pilot bushing/pilot bearing? Already removed?
The flywheel has heat checks. It should be re-dressed with a tan or red Roloc disc.
Old Oct 6, 2013 | 10:27 PM
73 ford guy
Totall thickness is 0.88"
Old Oct 6, 2013 | 10:30 PM
73 ford guy
Yeah I'll get it resurfaced. Is this always done by a machine shop or is there a way to just to knock off the heat marks?
Old Oct 6, 2013 | 10:42 PM
73 ford guy
I'm searching info on this right now. Seems I may need to countersink the flywheel bolts. My machine shop should of measured for this.
Old Oct 7, 2013 | 08:40 AM
rogue40's Avatar
rogue40
They have a machine that grinds the surface while holding it true. There is no way to do it by hand and keep it straight.
Old Oct 7, 2013 | 09:22 AM
mikeo0o0o0's Avatar
mikeo0o0o0
I'm going to rain on your parade.
I would say the flywheel has already been surfaced more than once and is now too thin.
I don't have a thickness spec but, unless the bolt heads are too thick (doubtful), that's about the only thing it could be.
Looks like your in the market for a new/good used flywheel.
Old Oct 7, 2013 | 09:45 AM
73 ford guy
I don't think so. I'll ask my engine builder today.
Little counter boring of bolt holes and shorter heads should bring her back to life.
I'll find the wear limits
Old Oct 7, 2013 | 09:52 AM
HIO Silver's Avatar
HIO Silver
I'll ask again, what happened to the pilot bushing/bearing?
Old Oct 7, 2013 | 10:43 AM
rogue40's Avatar
rogue40
Yeah that has me wondering now too.
Also, some of the friction pad rivets apper to be shined up. A clutch plate should be good for for than a thousand Ks, huh?
This gives a little information
https://www.ford-trucks.com/forums/6...hick-thin.html
I my opinion, though, I suspect the wrong clutch plate was used. But I also don't see any blind hole on the flywheel surface.
Old Oct 7, 2013 | 11:52 AM
Canus's Avatar
Canus
HIO Silver is on the right track here. If you are running a manual transmission without a pilot bearing in the rear of the crankshaft I'm surprised you haven't been plagued by other problems over and above the odd wear on your clutch disc. Better check the bearings on the input shaft of your transmission before you reinstall it.
Old Oct 7, 2013 | 04:37 PM
73 ford guy
It was fine. All carnage was on flywheel side
