Yet Another Question.
Old Oct 5, 2013 | 10:43 PM
Hoss5504's Avatar
Hoss5504
I have a 1999 ford F-250 7.3 4X4 and the battery light will flicker/slash on and off in the morning (I just got the truck and the guy said it was a new alternator) and the 4X4 light will flash driving down the road randomly Any ideas guys? I already did the normal stuff check cables and connections on the battery and alternator
Old Oct 5, 2013 | 11:00 PM
crop harvester's Avatar
crop harvester
as for the batt. light I would monitor voltage one of those ones that plug into cigg. lighter port from Walmart or Internet, voltage after batt. recovers from glow plugs [ couple minutes ] should be slightly above 14 volts,mines 14.2, getting batteries tested would be good. dont have any experiance with 4x4 light diagnostic.
Old Oct 5, 2013 | 11:05 PM
Hoss5504's Avatar
Hoss5504
The weird thing is it only does it in the morning till the truck warms up (and then after work) until the truck warms up
Old Oct 5, 2013 | 11:30 PM
crop harvester
batteries will have to recover from glow plugs and starter.depending on condition of alternator, batteries & connections how quick that happens.
Old Oct 5, 2013 | 11:52 PM
broke vet's Avatar
broke vet
@crop harvester gives good advice, Hoss.
How old are the batteries? New-new, last winter, 1999?
What voltage do you have across the battery before you crank it? After you start it but before you drive it? After you've driven it 10 miles or so? (Drive it!? Yeah, I know; it's a dirty job but somebody's gotta do it )
I recently read somewhere that some 4x4 indicators run off the PCM. I suspect that's the case with your '99 and that the PCM is fussing a little bit because the voltage is a little low immediately after you start the truck.
Old Oct 6, 2013 | 04:58 AM
Tugly's Avatar
Tugly
▲ Yup. all of the above.
Old Oct 6, 2013 | 05:26 AM
Cubawashere's Avatar
Cubawashere
@Hoss... do you have longer cranks to start in the morning? Maybe sign of battery(ies) getting weak. I agree with the rest of the above statements but rather than checking batteries in truck... pull each out and load bench test them. Checking them in the truck may give inaccurate readings. That can be done for free (if you pull out batteries yourself) at Advance parts stores for instance.
Old Oct 6, 2013 | 08:07 AM
Hoss5504's Avatar
Hoss5504
See the truck cranks right over snd starts right up on the morning or evenings
Old Oct 6, 2013 | 01:16 PM
broke vet's Avatar
broke vet
We can easily have you throw a couple thousand dollars at the truck, Hoss, and not fix the problem. Or we can have you make a few tests, precisely locate the problem, and send you on your problem-free way for a tenth of that. Or less, possibly.
Right now what we know for sure are the following facts:
  • The charge and 4x4 lights start blinking immediately after you start the truck
  • The lights go out once the truck warms up
  • The previous owner says the alternator is new
  • The cables and connections have been verified as sound
It could be the batteries, the alternator (new/rebuilt or not), the voltage regulator, the PCM, the light circuit, the light circuit driver, or any of another half a dozen things -- and some of those things are a proper bugger to get to. Without more information, all we can do is guess.
SoCal-Bob
36
Feb 15, 2019 12:54 PM
wakdady
Mar 13, 2013 09:21 AM
james734
Feb 20, 2011 11:43 AM
flyday58
Jan 3, 2011 06:53 AM
Benny2002
Jan 23, 2009 02:16 PM
