Heater core question
Old Oct 6, 2013 | 05:57 PM
Edmed's Avatar
Edmed
Originally Posted by mikeo0o0o0
Yup, that's the evaporator drain. It drains the condensation that runs off the evaporator.
You can see antifreeze leaking out so you do have a leaking heater core.
Here's what came on the drain from the factory, although what you have is fine, looks like you have the stock part.
Thanks Mike! Glad I signed up! Appreciate you getting me up to speed. Will wait on the one Ranger suggested and hopefully have her up and running.
Old Oct 6, 2013 | 06:21 PM
mikeo0o0o0's Avatar
mikeo0o0o0
No problem, always happy to help. If you get stuck on something just post a question.
Old Oct 6, 2013 | 06:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Most people are unaware that FoMoCo offered THREE different types of A/C for 1973/79 F100/350 & 1978/79 Bronco.
So, they're also unaware of this: 1973/79 F100/350: There are THREE different heater cores and FIVE different A/C evaporators, I kid you not!
C6OZ-18476-B .. Heater Core-Use with Hi-Output Heater
Also: 1978/79 Bronco & 1966/70 Falcon & 1966/72 Fairlane/Torino/Montego.
D3TZ-18476-A .. Heater Core-Use with factory installed Integral A/C or Hi/Lo Comfort Vent System / Obsolete
Also: 1978/79 Bronco.
D3TZ-18476-C .. Heater Core-Use with dealer installed Economy & Deluxe A/C or with heater only / Obsolete
D2AZ-19860-A.. .. A/C Evaporator-Use with Deluxe dealer installed A/C (Motorcraft YK-35) / Obsolete
1972/79 mIsc Ford/Merc passenger cars with dealer installed "hang-on" A/C // 1973/74 Econoline / 1973/79 F100/350 / 1978/79 Bronco.
D3TZ-19860-A .. A/C Evaporator-Use with factory installed integral A/C (Motorcraft YK-39) / Obsolete
1973/74 F100/350 / 1975 F100/350 before serial number W00,001.
D5TZ-19860-A .. A/C Evaporator-Use with factory installed Integral A/C (Motorcraft YK-54) / Obsolete
1975 F100/350 from serial number W00,001 / 1976/79 F100/350 / 1978/79 Bronco.
D4TZ-19860-A .. A/C Evaporator-Use with dealer installed Economy A/C (Motorcraft YK-50) / Obsolete
D8TZ-19860-A .. A/C Evaporator-Use with dealer installed Deluxe A/C with Hi/Lo Comfort Vent System.
1978/79 F100/350 & Bronco.
Factory installed Integral A/C is combined with the heater. A/C controls located in the same panel as the heater controls.
Deluxe dealer installed A/C combined with the heater. A/C controls located in HUGE dash bezel (see pic at left).
Economy dealer installed A/C not combined with the heater. See pic at right for A/C controls and etc.
Old Oct 6, 2013 | 06:52 PM
ranger429's Avatar
ranger429
Bingo! That's the one! Thanks
When you call to order make sure to tell them you want brass or they will ship you an aluminum core. I've bought from them before and they were great with service.
Old Oct 6, 2013 | 06:57 PM
Edmed's Avatar
Edmed
Wow! Great info. Love the exploded diagrams as well. Thank you
Old Oct 6, 2013 | 08:08 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Edmed, just so you know, you have what Ford called "integral A/C", that's the factory A/C.
Old Oct 7, 2013 | 09:02 AM
mikeo0o0o0's Avatar
mikeo0o0o0
In an earlier post you talked about changing the evaporator to save time and money. I wouldn't do that but, one thing I would consider changing while you're there is the blower motor. To change one you have to tear the whole thing apart. They aren't all that expensive and easy to get.
If you do change it be careful removing the blower squirrel cage. The ones for factory A/C are getting hard to find.
Old Oct 7, 2013 | 04:22 PM
Edmed's Avatar
Edmed
Thanks, Mike. I will add that to the order list today. I will be mindful of the cage as well. Is that something I can trust the locals with or is there one you recommend?
Ed
Old Oct 7, 2013 | 04:23 PM
Edmed's Avatar
Edmed
New vocabulary term for me!!
Old Oct 7, 2013 | 04:38 PM
Edmed's Avatar
Edmed
They were very nice. He asked what " mustang" I had, told him I didn't, but needed part 9022. He asked if I was sure that's what I needed...said yep ...actually I have no idea, but know you guys do! Thanks again.
Old Oct 7, 2013 | 05:41 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Ed
That's something that you can get locally. I like NAPA myself but this is something that you can kinda "price shop" for.
If you do change the blower motor you'll have to splice in the old plug. The new motor only comes with wire pigtail, no plug. Be sure to check rotation of the motor after you install the plug. Some replacement motors will have a reverse rotation if you hook up the wires orange/orange and black/black. If you check and its wrong, just reverse the wires.
vanceboroguy
Nov 24, 2014 09:09 AM
69ford99
1997 - 2003 F150
Nov 6, 2013 03:12 PM
dohc_chump
27
Sep 28, 2010 03:04 PM
Andy_H
Jun 12, 2007 12:18 AM
don_79f250
Dec 13, 2004 07:32 PM
