IDI Coolant Filter Project
Old Oct 29, 2013 | 12:15 AM
2500ak's Avatar
2500ak
I've seen this on other trucks, but I decided to do it on mine.
Snip the pressure expansion tank line and put a small universal filter on it. I doubt that it filters a whole lot, but it is a clever way to inspect the coolant.
Old Oct 29, 2013 | 07:32 AM
madpogue's Avatar
madpogue
Since the IDI has an overflow tank and not a reservoir, I'd reckon about 1% of the coolant ever flows through that. And good thing, too. If any significant percentage of the coolant flowed through a filter that size, it'd be done for in probably a month.
Old Oct 30, 2013 | 12:06 AM
speedwrench72's Avatar
speedwrench72
I installed a water filter just like that on my boat (Chevy) just used smaller fittings to reduce flow to filter 3/8 line works great, I use filters with out sca's in them for the boat. if you plan on installing turbo, all turbo's have a oil flow reducer orifice in the oil line as would an oil bypass filter, most turbo installation's drop the oil back where cdr was.
Old Oct 30, 2013 | 01:25 AM
2500ak's Avatar
2500ak
I've had good luck with the oil return port International put on the heads. I used it for my oil bypass filter.
I just unscrewed it with an 1/4 hex socket and threaded in a 1/4" NPT barbed fitting.
I know the filter has a flow control orifice but I ordered one from McMasterCarr anyway, that way the flow is restricted right at the block.
Here's the final version of the oil junction.
This is the oil bypass filter thread:
https://www.ford-trucks.com/forums/1...filters-2.html
Hotwheelbill
Dec 22, 2013 05:40 AM
Ryandee18
Oct 10, 2013 10:37 PM
Shadow913
Sep 23, 2012 10:09 PM
Ford4Life7.3
90
Jul 19, 2012 06:05 PM
TexasA&M
Aug 18, 2010 03:06 PM
