What Triggered Airbag Light Code 27
My airbag light is flashing 2-7 (two flashes, pause, 7 flashes, pause, repeat)...
I see on the forum that there is a fix for it, but honestly i don't really follow the PDF too well... can't even tell if the PDF is for a Ranger.
Here is my story and would love some help.
Truck Specs: 2005 Ranger Edge 3.0 V6 4wd Single Cab
Step 1 Took the seats out to clean the vinyl floors... I never turned the ignition or even put the key in the ignition while the seats were out. Took about a week of just spraying seats, let sun dry them out, repeat... put the seats back in.
Step 2 Took Ranger to carwash, popped the hood and sprayed off the engine bay... I did not squeeze the trigger so it was the lighter spray force of the car wash and I was at a good distance (not hitting it full force or directly)
So, did one of those above steps trigger the light?
I unhooked the battery cables, then unplugged the passenger airbag cable and blew into both ends and hooked them back up, then put the battery cables back on...
Turn ignition on and same code flashed again...
Any help, would be greatly appreciated... I love videos so if there is a video of someone fixing this issue please put up a link for me to follow... the PDF was just not helping me (I'm super deficient in this area)
thanks guys
How To Fix A Code 27 Air Bag Code on A Ford Truck | Bohack
