abs code 36
Old Nov 21, 2010 | 11:34 PM
customfoam's Avatar
customfoam
Exclamation abs code 36
I have a 2000 exp xls and came with mustang seats, did not have the original seats when i bought it, it does have the airbag light on and blinking 3 & 6 meaning 36, I understand it has to do with the seats maybe the plug is not connected, what can I do to get the airbag light out with out having the to replace the seats? Any help please.
Old Nov 22, 2010 | 07:06 AM
shorod's Avatar
shorod
So it's the SRS light that's on, not the ABS light as indicated in your subject line?
-Rod
Old Nov 22, 2010 | 04:44 PM
customfoam's Avatar
customfoam
yes the airbag light not the abs
Old Nov 22, 2010 | 09:08 PM
shorod's Avatar
shorod
LFC 36 in a 2000 Explorer indicates that the driver's side airbag circuit is shorted to ground, shorted to battery or ignition, has high or low resistance. Each of these conditions has a separate diagnostic trouble code. If you have access to a scan tool that can pull the specific diagnostic code that will help determine which fault is being detected and hence which pinpoint test to follow.
-Rod
Old Nov 22, 2010 | 10:28 PM
customfoam's Avatar
customfoam
well its time to see who has a scanner, I guess not all scanner can scan airbag codes correct?
Old Nov 23, 2010 | 11:24 AM
labc26's Avatar
labc26
see if the plug is connected if not connect the plug or if it is connected clean it with a Q-tip and alcohol light will go off
Old Nov 23, 2010 | 12:09 PM
shorod's Avatar
shorod
Correct. The standard consumer-grade of scan tool will only read powertrain diagnostic codes (those with a 'P' prefix). To gain access to other modules, such as various body modules, transmission modules, ABS, SRS, etc. requires a professional grade scan tool.
There are some ABS and SRS capable scan tools starting to enter the consumer market though, but apparently they are not yet being widely offered by parts stores for the "free code scan" services.
-Rod
brc777
1983 - 2012 Ranger & B-Series
Jan 6, 2017 01:34 AM
rmccbride
2015 - 2020 F150
Apr 25, 2015 06:38 PM
dogdude2003
Oct 14, 2014 09:10 AM
mudduc971
1997 - 2003 F150
Mar 12, 2014 12:43 PM
