Rough running truck
Old Oct 2, 2013 | 11:01 PM
ReBilld's Avatar
ReBilld
You have to cut the two plugs off and solder all of the wires for both plugs to the single SD plug. It's not hard at all.
Old Oct 4, 2013 | 09:29 AM
Oval_obsessed's Avatar
Oval_obsessed
Is there a special trick to get the rear valve cover bolt out that's under the AC box on the passenger side? It's giving me fits.
Old Oct 4, 2013 | 09:44 AM
oldbird1965's Avatar
oldbird1965
If I remember right, I used a swivel.
Old Oct 4, 2013 | 09:47 AM
farmert's Avatar
farmert
I have found it the easiest to get to that bolt from under the truck reaching up. You do know thaat you have to remove the small part of the heater box, with a vaccume hose running to it, to get the valve cover off.
Aaron Frazee
Jun 11, 2017 04:15 PM
Sean Estes
34
Aug 8, 2012 10:02 AM
Adam0331
24
Mar 5, 2009 09:57 PM
foxracing0934
Aug 19, 2008 09:48 PM
Clint40
Nov 11, 2007 04:30 PM
