Uvch testing
Old Jun 11, 2017 | 02:45 PM
Aaron Frazee's Avatar
Aaron Frazee
Uvch testing
My 97 7.3 has been giving me fits and it doesn't want to stay running. Runs for awhile then just cuts off. Already changed out the cps. Fixed it for 2 weeks did it again. Changed out the ipr and cleaned the connections on it and the icp ran for a few days better then ever then did it again. So I looked at uvch connections cleaned those with cleaner and tested the injectors came back with zero on all of them on the passenger side same thing with the glow plugs. Then just tested the front driver side same thing. Decided to pull the passenger side cover to take a look and everything looked to be in good condition and tested the uvch itself and it still came back reading zero. Maybe I meter is bad not sure but if it isn't what would be causing this issue. It stays running for various amounts of time from a few mins to 30 mins. Never any problem restarting it. And seems to be getting fuel with good 60psi. Unfortunately i don't have easy access to a reader. So I'm trying to narrow things down before throwing money at it. Plan to pull the driver side vc to take a look there but fell like it will be the same. Any suggestions. My next thought is the idm but I don't have access to a good one of those to test if mine is bad.
thanks in advance
Old Jun 11, 2017 | 03:18 PM
oldbird1965's Avatar
oldbird1965
The new cps, is it a motorcraft or international one? Our trucks don't like parts store ones. Did you ever see a check engine light? As you said it would be nice to see if there are any codes. Welcome to the forum!
Old Jun 11, 2017 | 03:30 PM
Aaron Frazee
Ordered the cps from riffraff diesel and the ipr both where ford oem it had a light Gray one on it one i got was dark gray. And thanks I've done a lot of reading but have hit a dead end so here I am asking for help. Would like to do it myself but if not guess I'll have to take it some where. Just changed the oil also and checked the level right at full
Old Jun 11, 2017 | 03:34 PM
Aaron Frazee
O yeah first few times the wts and cel would flash for a few seconds then go away. Never stays on long
Old Jun 11, 2017 | 04:04 PM
oldbird1965
Is your fuel heater still plugged in? wts light is on same circuit.
Old Jun 11, 2017 | 04:15 PM
Aaron Frazee
Nope that's been unplugged since I've owned for the last 2 yrs. Only issues I've had was a leaky water pump till now.
flyyboy
43
Jan 12, 2015 06:28 PM
Studawg
77
Jun 28, 2012 01:23 PM
m0nkee221
13
Dec 23, 2008 06:08 PM
Dizz0129
Jun 16, 2007 10:20 AM
FitOver50
Jul 28, 2005 08:58 PM
