IDI injector question
Old Oct 1, 2013 | 12:23 PM
tigerblood's Avatar
tigerblood
I found an injector in my 1990 7.3 IDI diesel leaking today, can I replace just one injector if only one is leaking fuel or do they all need to be replaced?
Old Oct 1, 2013 | 01:17 PM
jas88's Avatar
jas88
It's OK to replace just one IMO.
jas88's Avatar
jas88
Old Oct 1, 2013 | 01:25 PM
tigerblood's Avatar
tigerblood
This is a truck I got last weekend and am planning to sell soon, do you think replacing just the o rings on the injector would stop the leak, I took it out and sealed the threads to the leak has to be because of the o rings or the piece the fuel likes connect to
Old Oct 1, 2013 | 01:49 PM
jas88's Avatar
jas88
Oh, so you mean leaking externally? Usually, when someone says "leaking injector" I think of internally leaking, which will cause a knock. Yes, I would try replacing the o-rings and return lines first. That is a very common maintenance item on the IDI, and you can buy a kit to do it all on eBay:
http://www.ebay.com/itm/Ford-International-7-3L-IDI-Diesel-Injector-Installation-kit-91-94-/221209309409?pt=Motors_Car_Truck_Parts_Accessories&hash=item33811a30e1&vxp=mtr#ht_1864wt_934
Old Oct 1, 2013 | 03:48 PM
tigerblood's Avatar
tigerblood
yep, leaking externaly on top of the motor,somewhere between the threads that screw into the block and the hard line on top of the injector, ill give o rings aq shot first, thanks for the help
DBGrif91
Feb 11, 2018 10:30 AM
run6.0run
Jan 17, 2014 02:06 PM
Farmboypowerstroke
Jul 19, 2011 01:52 PM
EffieU
Nov 25, 2010 09:26 PM
daw00l
Sep 9, 2009 11:20 PM
