Fuel Pump Arms?
Old Sep 30, 2013 | 10:02 PM
scott.maki's Avatar
scott.maki
Fuel Pump Arms?
I recently purchased a fuel pump for my 390. When I pulled the old one the pump arm was different from the new one. New pump has kind of a bump at where the arm starts to curve old is more flat. Parts store said that was the only one listed for my 390 so installed it. The motor runs fine but fuel pressure bounces between 5 and 6 psi where as it stayed at a solid 6 psi with old pump. Change pumps because motor had been sitting awhile and didnt want gas in the oil. Are the different pumps for FE's? Will i mess somethin up using the new one? Sorry for the long post. Thanks in advance.
Old Oct 1, 2013 | 05:51 AM
jowilker's Avatar
jowilker
Question, Is the engine running like it is getting enough gas??
If yes find something else to fret over.
John
Old Oct 3, 2013 | 10:04 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
If you lay both pumps side-by-side, are the arms the exact same length and angle?
I'd take John's advice, if it runs good, nothing to worry about
ralphyboy
Feb 2, 2016 01:57 PM
Old93junk
Illinois Chapter
May 11, 2009 06:38 PM
Tedybear
Dec 14, 2007 08:42 PM
71ranchero500
Oct 21, 2003 11:58 PM
mallardgreen
Mar 19, 2003 08:43 AM
