Installing a fuel pump
Old Oct 21, 2003 | 07:13 PM
71ranchero500's Avatar
71ranchero500
I am going to install a new fuel pump for my 71,302. I was looking at the directions and it doesn't seem to hard to do. i wanted to know if it will be a simple task or if i may run into any problems while installing it, and turn a 30 min project into a 3 hour project (like how it normally happens when working on my truck). Any advice would be great and much apreciated since this is my first time replacing one.
Thanks
Old Oct 21, 2003 | 07:50 PM
jwtaylor's Avatar
jwtaylor
It is carbed correct? Go for it no surprises just wrap the lines when you loosen them should fuel wanna spray and lube the pump arm with a little oil just to be on the safe side just a little will do. later
side note I have just accepted the fact that no matter what I do or how fast I think I am going it takes longer than expected. haha
Old Oct 21, 2003 | 09:03 PM
71ranchero500
sounds good thanks a bunch
Old Oct 21, 2003 | 09:11 PM
circledirt's Avatar
circledirt
Just be sure to get pump arm under the pump drive bolted to the cam.
Old Oct 21, 2003 | 09:16 PM
circledirt's Avatar
circledirt
Oh, and clamp off fuel line from tank before disconnecting from pump. It siphons real fast,
Old Oct 21, 2003 | 11:58 PM
71ranchero500
thanks again i'll let you know if i blow anything up i might start on it tomrrow when i get my distributor im going to put in
maytea
66
Mar 31, 2015 05:40 PM
hillcountryflt
WTB - Parts & other
Mar 27, 2015 04:57 AM
71 f-100
Nov 25, 2012 05:26 PM
John Martin Dipolito
Nov 8, 2012 03:56 AM
carnut122
20
Oct 4, 2009 08:14 AM
