Noise
Old Jun 18, 2003 | 07:31 PM
steaks73's Avatar
steaks73
Question Noise
I have a new '03 Expedition. Whenever I turn the wheel at very low speeds there is a noticable grinding noise coming from the front end. Any ideas?
Old Jun 18, 2003 | 07:50 PM
TrukMan's Avatar
TrukMan
Noise
I have the same problem. I hope someone has some ideas. Mine does it when I turn the wheels and hit the gas. I think it may be the tires.
Old Jun 19, 2003 | 06:22 AM
ppo2's Avatar
ppo2
Noise
Turning your wheels at a 90 degree (or near) angle will make the tires squeak especially at very low speeds like getting into a parking space, this is normal. The grinding noise of course is mechanical, if the trucks are front wheel drive (which they're not) then I would say maybe the CV joints (constant velocity) If there's someone more mechanically inclined to please jump in, there's a joint of some sort with a boot cover, similar to a CV joint. Perhaps that's what these noise are coming from?
Drive safe,
Dan
Old Jun 19, 2003 | 09:18 AM
BHussin's Avatar
BHussin
Noise
I bought my '03 on Memorial Day and have noticed the same noise.
Old Jun 19, 2003 | 12:49 PM
TrukMan's Avatar
TrukMan
Noise
Mine is more like a vibration. I can even feel it sometimes when I am moving in a straight line.
Old Jun 19, 2003 | 02:00 PM
Prowler826's Avatar
Prowler826
Noise
I have the same issue - plus a "clunk" when shifting into A4WD. There's a TSB out on this:
https://www.ford-trucks.com/forums/s...&threadid=8746
Old Jun 19, 2003 | 02:26 PM
tkd's Avatar
tkd
Noise
I have all of these problems. Have not had a chance to get to a dealer. I figure if it breaks, I'll call Ford & they can come get the piece of dung (nope, don't much care for the 03 I'm driving)
Old Jun 19, 2003 | 08:25 PM
TrukMan's Avatar
TrukMan
Noise
Ok, I took my truck in and there is a (recall) or SB on the front end differential that causes the wheels to spin differently. They replaced a spring and all is ok now. Take it in and have them pull up the SB for the 03 trucks. They will see it.
Good Luck
Old Jun 20, 2003 | 08:54 AM
97expy5_4's Avatar
97expy5_4
Noise
Bringing this thread back to the top, My buddie has an 03 Expy with the same problem. I wanted him to see this thread....
Big Mick
Old Jun 20, 2003 | 11:22 AM
wacnstac's Avatar
wacnstac
Noise
Yeap they replaced a spring on mine and it seemed to fix the problem.
