Just bought a new to me 2011 F250 King Ranch CrewCab w/6.7 Powerstroke, auto, 4x4, 3.55 gear, FX4 offroad option, and loaded including these huge wheels. So, what is the functional reason why I'd want to keep the the big wheels? Per the Michelin website, they are taller than the factory standard 18" and effectively reduce the gear ratio from 3.55 to something in the 3.4x range. Sure, they are pretty, that I get. Is that all? Thanks.
yup. those big wheels are for the bling factor.
it aint a real truck unless it has giant useless rims and wheels on it that cost 4 times more than regular old 16's.
In general, the idea behind bigger wheels, other than the bling factor, is they're typically fitted with lower profile tires. Those are supposed to give less sidewall flex.
Great answers, thanks. I guess BLING was important to the original owner. Thanks for the heads up about reduced carrying capacity, I need to check that out. Not ready to make a change at this point since I'm planning to use it more for the towing convenience of my boat rather than carrying capacity....but there's the possibility of finding a used truck camper...and that plus tongue weight would impact carrying capacity. Thanks guys.
Like said, the bling factor and better handling. However, at recommended inflation pressures, these trucks handle good for a truck. All the lower profile tires do is create a harsh ride. If you plan on doing anything offroad, even if it is just down some country lane with potholes or tree roots you want the most flexible sidewall to absorb the shock. Just ride in a stock vehicle with stock tires and one where the owner has opted for low profile wheel and tire combo. The low profile setup is much more harsh. In direct proportion to how low of a profile tire is used. On these trucks, I believe the minimum wheel now that will work is 17 inches with only the most basic trucks with that size. Most trim leves have 18 inch with the premium "bling" models 20 inchers. But then how many king ranches actually see a dirt road let alone true off-road.
BTW, the same tire in smaller wheel sizes but same overall sizes are way cheaper.
I agree. Having 33s and even 235s on mine rides a hell of a lot smoother than low profile trucks, plus I hate how they look. They don't look like trucks anymore, they look like they are catering to babies who are afraid to get dirty. For god sakes build a real truck again, one designed to do work with less comfort.
The bling factor and marginal handling benefit is about it. Not worth the extra weight, even harsher ride, increased cost of tires, more chance of damaging the rims and etc IMO. If you want a vehicle that takes corners well a 6k-8k lb truck is not where it is at. The smallest available wheel option in aluminum is what I buy.
Depends on what you do with it. I only went 250 because the 150 can't take the weight of most 5th wheel pins. I like comfort and I will rarely if ever go offroad on anything else than dirt paths. The XL models have 17" wheels and those are built to work.
That being said I'm glad mine has 18" wheels and not 20". My previous 2005 MDX had 17" wheels and the 2008 MDX has 18"; the ride is so much harsher. Maybe some people like taking corners 10% faster in their new SUV; I prefer taking potholes easier the rest of the time.
If they built one with less comfort and built to do more work they'd have to go back to makeing manual X/Missions avaliable again. Ain't gonna happen,don't hold your breath.
I disagree with you on the manual trannys. I believe they quite manuals because of the tune and output of these engines, most people would be tearing the drivetrains apart with improper use. In addition, the autos are as capable as any manual is without going to extreme heavy duty units found in bigger trucks.
the auto flat out works and works hard, regardless of the ya-ho driving it.
