Climate control slider problem
Old Dec 18, 2010 | 03:02 PM
ford 6.9's Avatar
ford 6.9
does anyone know why my slider wont go all the way over to hot???. Ive replaced the heater core too but its getting could enough out that i would like to have heat past luke warm. I know these things can sweat you out but its getting a little cold.
Heres a pic. That is as far over as it will go.
Old Dec 18, 2010 | 03:04 PM
oreocreaming's Avatar
oreocreaming
check the cables behind it. end of it might be bent or it could use a little spray lube in the lines.
Old Dec 18, 2010 | 04:09 PM
ford 6.9's Avatar
ford 6.9
Its stuck like wont move any farther over. Its been like that since i bought the truck It moves free the other way tho. I tried to take the climate control out but I couldnt get it out. had the radio and stuff out but couldnt see the cables.
Old Dec 19, 2010 | 12:01 AM
farmert's Avatar
farmert
As Oreo said check you cable. I might have bent the center wire or the clamp that holds the outer part of the cable might have slipped, not allowing the blend door to shut all the way. Did you check the blend door when you replaced the heater core? Ball point pens and the like have a habit falling down the defrost tubes and block the blend door.
Old Dec 19, 2010 | 12:16 AM
ford 6.9's Avatar
ford 6.9
no i didnt check the blend door but you hear it flapping back and forth with i change from defrost to vent etc. It just like hits something when i try to go all the way over to warm. Ill take the radio out again and see if I can see the cables. I couldnt see anything last time with the radio out maybe I was looking in the wrong spot.
Old Dec 19, 2010 | 12:19 AM
oreocreaming
remove the radio and remove the "wood" trim around it. you can get a better view. you can remove the control panel too with a few screws. get a good view. i havent taken mine apart but if its like my chevys then its a hard wire in a sleeve. if the hard wire gets a kink in it then its not gonna let it slide all the way. check both ends of the cable and see if theres a bend in either end.
Old Dec 19, 2010 | 04:04 AM
DPorter's Avatar
DPorter
cable ends should be visible under the glove box. They can slip in the clips there and will cause this issue.
Old Dec 19, 2010 | 09:48 AM
ford 6.9's Avatar
ford 6.9
Thx ill check it out when its not snowing out side
bl2009
1997 - 2003 F150
Feb 11, 2017 09:07 PM
Amish Ford
Jul 24, 2016 05:24 PM
davehaynes
22
Jul 12, 2011 06:15 AM
jepps
Mar 25, 2006 09:18 PM
Zebra
Oct 11, 2003 10:57 PM
