Sponsored by: Real Truck
Flasher problems
Old Sep 28, 2013 | 08:54 PM
ZekeD's Avatar
ZekeD
Flasher problems
I have a 2004 HD 4X Short Box Dually Off Road.
When the ignition is on the flasher module under the dash slowly (about 1/2 speed from the turn indicator speed) cycles.....click...click...click.
It stops when I apply brake pressure to the pedal.
It cycles whether the truck is running, in motion, stopped, or just with the ignitn in the run position.......anytime the brake is not applied.
Any ideas why the flasher is doing this? I have replaced the flasher module once already as the orig. one failed. Presumeably from the same problem.
Thanks
Zeke -Oregon
Old Sep 29, 2013 | 12:32 PM
SC_Hoaty's Avatar
SC_Hoaty
Doesn't the flasher always stop when the brakes are applied? Is the flasher switch the culprit?
Old Sep 29, 2013 | 03:43 PM
ZekeD's Avatar
ZekeD
Flasher problems
Yes they do.... But my flashers are not on. And if they are on they cycle about one time per second. In this case, no flashers, no brakes applied, no turning lights, head and running lights on or off, if you are quiet you can hear the flasher cycle at about once per 2 seconds. Even with the engine off, but the key on.
Zeke
Old Sep 29, 2013 | 05:45 PM
SC_Hoaty's Avatar
SC_Hoaty
Short to ground someplace in the flasher circuit? Get a wiring diagram, a meter, and a lot of patience!
Old Sep 29, 2013 | 05:54 PM
SC_Hoaty's Avatar
SC_Hoaty
The flasher relay is in Aux Relay Box #1
You could just pull the relay and live without flashers. Turn signals should still work, I believe.
Old Sep 29, 2013 | 05:58 PM
SC_Hoaty's Avatar
SC_Hoaty
On second thought, that may take out the turn signals, too.
Old Sep 29, 2013 | 07:03 PM
ZekeD's Avatar
ZekeD
Flasher
When I had the module out I forgot to try the turn signals. The "module" that I replaced had 4-5 prongs on it, and plugged into a breadboard just to the right of the fuse access panel ( kinda under the ashtray). About 1 in cubed.
Thanks, I'll look for a short.
Zeke
Old Sep 29, 2013 | 07:10 PM
fastpete's Avatar
fastpete
Try changing the flasher unit. It may be shorted on the inside. The turn signals should work off of a different flasher unit.
learpilot
May 14, 2016 09:43 AM
wulleebullee
13
Oct 26, 2011 09:19 PM
76-hi-boy
May 30, 2009 01:32 AM
n2music
Electrical Systems/Wiring
Mar 29, 2004 07:23 PM
