Side Mirror Lamp Replacement
Old Sep 28, 2013 | 10:54 AM
Traveling Man's Avatar
Traveling Man
Can someone tell me how to remove the amber lense to replace the lamps on the side mirrors? Don't want to break something.
Old Sep 28, 2013 | 11:09 AM
sdetweil's Avatar
sdetweil
between the glass and the frame about 2 inches up from the bottom of the mirror is a clip that holds the amber lense into the mirror housing. use a small screwdriver to unhook the clip.. then the lense slides out toward the front of the vehicle.
Old Sep 28, 2013 | 11:16 AM
Traveling Man
Great, thanks for the tip.
Old Sep 28, 2013 | 11:19 AM
sdetweil's Avatar
sdetweil
tilting the mirror IN all the way makes more room for releasing the clip.
Old Sep 28, 2013 | 01:06 PM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
Cool, thanks for the tip. Reps sent.
Old Sep 28, 2013 | 01:23 PM
sdetweil's Avatar
sdetweil
check that the bulbs are seated. I smacked a concrete wall with the mirror at the tollbooth, and the lights didn't work. when I pulled the lense, both bulbs were sitting in the bottom..
both worked ok after putting them back in the sockets.
Old Sep 28, 2013 | 04:32 PM
Traveling Man
Yep, no problem once I was coached.
Richwon4
Jun 8, 2016 01:31 PM
rg8043
Jun 22, 2012 10:20 PM
greyfox503
Jun 9, 2011 11:23 AM
myEXisFAT
Mar 28, 2007 10:07 PM
flagator84
2004 - 2008 F150
Aug 12, 2004 10:32 AM
