360 tuning
Old Sep 28, 2013 | 08:34 AM
LittleG's Avatar
LittleG
360 tuning
I just installed a new comp cam 270h in my 360. So far everything seems to be running ok. When you first start the engine and before it gets to normal running temp, it sounds great with a really nice lope at idle. As the temp gets up it seems to lose the hit at the same idle.
Does this mean I have not adjusted the carb correctly or is there something else I need to look at. I'm not one for ******* the crap out of it but I want it to sound cool as I'm tooling around town. Before she gets warmed up..... She sounds coooool.
Old Oct 5, 2013 | 07:22 AM
captchas's Avatar
captchas
Guest
270 h isn't a really wild cam still it should have a little rough lope to the idle, take a can of brake or carb cleaner and spray it around the carb base and intake gaskets, if the idle goes up or smooth's out you just may have a vacuum leak
also when changing a cam re jetting of the carb properly is a most do. another possibility of being lean. which I suspect you may be dealing with.
Old Oct 5, 2013 | 07:37 AM
LittleG's Avatar
LittleG
I was wondering about the jets. I'm running the stock jets in the Holley 750. I believe they are 72s. Any idea which size I should try next?
LittleG
Oct 3, 2013 10:01 AM
rustywheel68
Apr 18, 2013 08:45 PM
forddude66
Feb 6, 2013 11:39 PM
1982fordf100
Oct 20, 2006 08:20 AM
bufordt
Jun 22, 2001 06:46 AM
