Another transmission I.D. question
Old Sep 27, 2013 | 09:25 PM
pux17's Avatar
pux17
Hi guys, This is odd. I've got a '96 f150 4x4 Off Road auto.
Because It only has 15,000 documented miles on it, I went and ordered the letter from ford showing how it was built. (The only thing I don't have is the window sticker) The letter shows that it has the 4R100 transmission instead of the expected E40D behind the 351w. Reading these boards, I see that the 4R100 was the upgraded, and replacement, for the E4OD in 98 and should not be in it. How can I better verify what trans I have? Is there a telltale label somewhere? Is there a physical difference? Or are Fords records inaccurate?.... The pan has 20 bolts as they both do. TIA
Old Sep 27, 2013 | 09:59 PM
rla2005's Avatar
rla2005
The 4R100 was not never installed in a OBS truck. You have an E4OD regardless of what that letter states. Yes, Ford's records are that inaccurate.
clong
1997 - 2003 F150
May 8, 2014 10:36 AM
1995_f150
Jan 8, 2012 08:48 AM
Roger T. Pipe
Dec 29, 2008 05:32 PM
MJKennedy
May 11, 2008 07:24 PM
hudson
1978 - 1996 Big Bronco
Nov 15, 2003 03:31 PM
