1978 - 1996 Big Bronco
Transmission
Old Nov 15, 2003 | 08:08 AM
hudson's Avatar
hudson
Transmission
I have a 96 Bronco, which is a better trans A4OD or 4R70W and how do Itell which one I have?
Old Nov 15, 2003 | 01:45 PM
greystreak92's Avatar
greystreak92
Well the E4OD was the automatic. Personally have never had any experience with the other you mentioned and wasn't aware of any other automatic available in 96. The M5OD was the manual 1/2 ton tranny that you could get. The E4OD is huge and most trannies can be identified by their pan. By 96 the E4OD had been improved quite a bit from its earlier versions that were susceptable to hard shifting and premature death.
Old Nov 15, 2003 | 03:31 PM
Torky2's Avatar
Torky2
Check your door frame sticker. E4OD is TR code E. If you have a 351 (5.8L) you probably have the E4OD. But if you have a 302 (5.0L) you probably have the 4R70W.
These two auto's have different heritage:
AOD to AOD-E to 4R70W
C6 to a 4spd. design called E4OD, later to 4R100
