swapping engines
Old Sep 27, 2013 | 03:19 PM
1985f250 6.9internat's Avatar
swapping engines
What all do I need to do to take a 6.9 international out of my 1985 f250 and replace it with a 7.3 from a 1986 f250? The only reason I am doing this is because my 6.9 has 2 dead cylinders and my buddy has a good 7.3 that hes willing to sell me.
Old Sep 27, 2013 | 06:45 PM
Bonanza35's Avatar
Bonanza35
I think they still had the 6.9 in 86. At least that's whats in mine. Can't help you on the rest but if it is IDI it should be the same as far as I know.
Old Sep 27, 2013 | 07:03 PM
Chevy_Eater's Avatar
Chevy_Eater
Yep, the 6.9 was used through '87. If that '86 has a 7.3 it's not original.
Pretty straightforward swap though, externally the engines are the same.
Old Sep 28, 2013 | 08:34 AM
brads93 idi's Avatar
brads93 idi
Unless its a newer motor it should just slip in
Old Sep 28, 2013 | 10:02 PM
lindstromjd's Avatar
lindstromjd
It wouldn't even matter if it was newer up to a 1994 engine. The only one that wouldn't work is a powerstroke. And they will, but not without a lot of extra fabbing and work. Any 6.9 or 7.3 IDI will fit right in there and work like it was factory.
Old Sep 29, 2013 | 01:31 PM
brads93 idi
No the wire harness is different after 92 cause I did a swap from a 92 into a 91 and I had to make the harness fit
Old Sep 29, 2013 | 01:55 PM
lindstromjd
Harness and engine are two completely different things for what OP was asking. The only thing he'd need to change on a newer engine would be the glow plugs, or glow plug connectors.
Fireman_dave
Oct 6, 2011 12:02 PM
thedieselkid
39
Dec 23, 2009 05:59 PM
mydieselpower86
Feb 18, 2006 04:10 PM
Chris Iverson
Feb 12, 2004 08:30 PM
