64 column parts source
Old Sep 27, 2013 | 01:07 PM
salf100's Avatar
salf100
Need a rebuild. Can someone provide are list of what's needed and where to buy.
Old Sep 27, 2013 | 03:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
64 column source
Please, when asking questions, list all the pertinent info.
What's wrong with the column? F100, F250 or? 2WD or 4WD? 3 M/T, 4 M/T or A/T?
When I know the answers to these questions, will post the parts catalog pic of the column, what the usual 'wear' parts are and where the parts can be found.
Old Sep 27, 2013 | 07:18 PM
salf100's Avatar
salf100
SorryND. The column is in fare shape but never been rebuilt. I'm in the process of rebuilding my steering box and figured why not. I've been slowly rebuilding the truck one part at a time.
Veh is 2wd, 64 F100, 292 w/ 3 on the tree.
Old Sep 27, 2013 | 10:19 PM
NumberDummy
1964 F100 2WD (), 292 w/3 M/T
Pic actually represents 1965/70 F100/250 2WD. 1964 F100/250 2WD is slightly different inre to upper/lower bearings/sleeves location. 1971/72's have 2 spoke steering wheels.
Basic part numbers only shown in Illustration Section. Text section required to get complete part number...which I'll list if asked.
Upper/lower bearings (3517) and nylon sleeves (3518) available from Ford.
Shift tube (7212), 3 M/T shift lever (7210), shift collar (7228), selector lever bushings (7343) at bottom of column, inserts, spring in shift lever (7B215 / 7208) available NOS
Other parts may be available NOS or repro'd.
Old Sep 28, 2013 | 11:03 PM
Jeff64F100CrewCab's Avatar
Jeff64F100CrewCab
Just a word of caution when messing around with a steering column. I haven't taken mine apart, so I haven't been in there yet, so keep that in mind. My right front turn signal doesn't work, and I traced down the problem. It appears that some wires from the turn signal that go through the column and the one for the right front is open (an broken wire) in the column and that is the cause of the non working signal. Not something easilt fixed without disassembling the column. The caution is that wires could look fine, but after wiggling them around, check for opens that may not be visible before reassembling them, particularly original wires.
Old Nov 13, 2013 | 12:34 PM
salf100's Avatar
salf100
Pic actually represents 1965/70 F100/250 2WD. 1964 F100/250 2WD is slightly different inre to upper/lower bearings/sleeves location. 1971/72's have 2 spoke steering wheels. Basic part numbers only shown in Illustration Section. Text section required to get complete part number...which I'll list if asked. Upper/lower bearings (3517) and nylon sleeves (3518) available from Ford. Shift tube (7212), 3 M/T shift lever (7210), shift collar (7228), selector lever bushings (7343) at bottom of column, inserts, spring in shift lever (7B215 / 7208) available NOS Other parts may be available NOS or repro'd.
ND - regarding this sketch, is the assembly order the same for my 64? I'm also having difficulty locating some of the parts. The was a large rubber bushing inserted at the base of my column, a small tapered rubber bushing inserted on the bottom of the steering shaft inside the column tube and my shift linkage did not have plastic spacers like displayed in the sketch. Only had a steel C spacer between the linkage. There are photos of the items I'm my album. Any help is appreciated.
Old Nov 14, 2013 | 02:41 PM
salf100's Avatar
salf100
Ok for those interested I located the large bushing at the base of the column from CJ's Rod and Machine. Little pricy but I called everyone with no luck.
Old Nov 16, 2013 | 03:14 PM
salf100's Avatar
salf100
Anyone have a blow up view of a 64 steering column, not 65-66?
Old Nov 16, 2013 | 10:30 PM
Broomfieldbum's Avatar
Broomfieldbum
I bought the parts book on PDF, I hope this helps!!
Old Nov 16, 2013 | 10:42 PM
salf100's Avatar
salf100
Man thanks! You happen to have the parts nomenclature list? I'm trying to put this thing back together and didn't take enough notes in the disassembly process.
Old Nov 16, 2013 | 11:12 PM
Broomfieldbum
What do you mean the parts nomenclature list? This is just about as good as it gets for Ford stuff, as far as I know. I did my column, and it went pretty easy based upon the first diagram posted. I actually don't know of any better diagram.
Uni Moe
Aug 6, 2017 07:11 PM
Jmwinter
Jun 5, 2016 07:34 PM
pwstark
Feb 22, 2013 08:47 AM
Ki-Adi-Mundi
19
Mar 29, 2012 04:41 AM
lance_1
Jun 7, 2000 09:17 PM
