Brought my rig to OK4WD in stewartsville NJ, and they found
1.track bar ball joint is worn
2.needs new upper and lower drag link
2.track bar upper bushing is worn
I can understand the ball joint, and bushing, but why the drag link?
Also, they say the trackbar ball joint is only made by Ford, and not greasable.
They installed a bilstein damper few months ago, but obviously didn't do much.
Any suggestions. Truck only has 38,000 miles and tires are worn, and if i have to replace these parts every year, that's very expensive. I only have the truck 14 months.
I have 35k on my truck and I have an intermittent (20-40s interval) vibration coming from the right front that sometimes escalates to body shaking levels. I have newly balanced tires and new Bilsteins, so my next candidates are the bushings.
