67-70 Steering Wheel on 71-72 Colum?
i wonder if i can restore my stock column then. i can buy the horn and wheel parts easily just wasn't sure if it would bolt up. should i hire a repair shop to install the parts since i need a new turn signal switch? i thnk wires need pulled threw column and i don't think my back could hold out long enough for me to do it.
Same 3 spoke steering wheel, repro'd by DC in black only: 1960/63 Falcon/Comet / 1961/66 F100/250 2WD / 1966 F100 4WD / 1966/73 Bronco / 1967/70 F100/250 2WD/4WD & F350.
Same 2 spoke wheel (except 1975/77 F100/350/Econoline with Speed Control), repro'd by DC in black only: 1971/77 F100/350 / 1974/77 Bronco / 1975/77 Econoline.
3 spoke wheel uses a horn button or horn ring / 2 spoke wheel uses a vinyl horn pad that contains the horn switch.
DOTZ-13341-B .. T/S Switch / Obsolete ~ 1969 F100/350 from serial number G30,001 & 1970/72 F100/350.
C2OZ-13A821-A .. Horn Brush & Insulator Kit / Reproduced ~ Except 1971/72 = Located within a hole on the outside of the steering wheel, visible when horn button/ring removed.
Applications: 1961/66 F100/250 2WD / 1966 F100 4WD / 1967/72 F100/350 // 1961/66 Thunderbird / 1963 Falcon Sprint / 1963/64 Galaxie/Fairlane / 1964 Falcon / 1965 Mustang w/a generator.
Same 3 spoke steering wheel, repro'd by DC in black only: 1960/63 Falcon/Comet / 1961/66 F100/250 2WD / 1966 F100 4WD / 1966/73 Bronco / 1967/70 F100/ 250 2WD/4WD & F350.
So, I gave you the applications for the 2 & 3 spoke steering wheels, horn ring/button, vinyl horn pad.
Gave you the part numbers/applications for the late 1969 & 1970/72 T/S switch and the 1961/72 horn brush and insulator.
geosche
02-24-2014 06:13 AM
denisontexas
02-22-2005 08:41 PM
