Will it tow ok?
Old Sep 26, 2013 | 09:36 PM
superhooperduty's Avatar
superhooperduty
Will it tow ok?
Thinking of buying a ew 2014 F350 Crew 4x4 8' box, 6.7.
I tow a 6800 lb travel trailer with a boat on top of truck. Question is the truck I'm looking at as 3.31 rear gears, the 2005 6.0 I have now has 3.55 gears. will the new truck pull as well as the old? With the extra torque will the new truck pull as well as the old off the line and up hills?
thanks
Old Sep 26, 2013 | 09:57 PM
mhoefer's Avatar
mhoefer
400, 800. Gears will not be a problem from what I have seen on this board. Remember you have also got a true 6 speed to boot. That's a light trailer for a SD, even with the wind resistance of boat on top.
Old Sep 26, 2013 | 10:59 PM
majkthreads's Avatar
majkthreads
Just picked up that same truck in a dually and pulled our new fifth wheel toyhauler this weekend. 19,000lbs without the toys in it.
Pulled it like a dream. Pulled better than our 2012 F250 SRW pulled our travel trailer. In fact we averaged 1.8 miles per gallon better in the dually.
The 2014 will pull it like there isn't anything back there.
Old Sep 27, 2013 | 02:35 AM
desertnomad's Avatar
desertnomad
Very light load. 6.7L won't even feel it.
Old Sep 27, 2013 | 04:56 AM
tomstoner06's Avatar
tomstoner06
Don't worry about the gear difference. There is basically no change between the two do to different tire size.
Old Sep 27, 2013 | 07:57 AM
CarlT100's Avatar
CarlT100
I think you will be very pleased with the 6.7. It will easily handle your load.
Old Sep 27, 2013 | 08:25 AM
SavageNFS's Avatar
SavageNFS
I used to have a 6.0L that was set-up nice. It pulled outstanding and I didn't want to mess up a good thing. I had a 6.4L and a 1/2 gasser in between the 6.0L and my 6.7L but I can tell you that a stock 6.7L will out pull a 6.0L every time. Even with 3.31 gears pulling against the wind, up a 7 degree incline, it will out perform a 6.0L pulling with the wind, on level ground, with a 3.55 rear end. I will add the ride quality will be an unreal improvment. Do what I did...tote your trailer nearby the dealer and take it for a pull with the new truck and see the difference to yourself. My dealer let me pull the trailer right on the lot (my tag, not my fiver). Most will not. Find a big parking lot and tell the salesman you need an hour. Go hook up and try it for yourself.
Old Sep 27, 2013 | 09:55 AM
majkthreads
Or just buy it and love it like we do.
Old Sep 27, 2013 | 09:28 PM
superhooperduty
Smile
I was under the impression that both my 05 and the 2014 had 18" tires? At least the info states 18" is standard on the Lariat, doesn't my 05 have a true 6 speed?
And thanks, gonna pull trailer
Old Sep 27, 2013 | 11:41 PM
Painted Horse's Avatar
Painted Horse
Your 05 has a 5speed tranny
The 3:31 gears come with the 18" wheels. While the 3:55 usually come with 20" wheels , So effectively you get about the same ratio after taking the difference in tire diameter into consideration.
Old Sep 28, 2013 | 11:13 AM
wtrlogd's Avatar
wtrlogd
I've put 60K on my truck since May of this year, hauling RV's.
My 3:55 and 17" wheels are perfect where the speed limits are 55-60 mph or less, but I'm really wishing I had gone with the 3:31 when the speed limits get higher.
The only thing you'll notice with the load you're describing, is less fuel economy, and a better ride due to some weight on the truck.
Old Sep 28, 2013 | 11:18 AM
sdetweil's Avatar
sdetweil
hm.. I thought it was (unless u changed wheel sizes for some reason)
3.55 and 20's
3.31 and 18's (my 12 250)
17's are on the dually with 3.73 (my 12 350 drw)
Old Sep 28, 2013 | 11:40 AM
wtrlogd's Avatar
wtrlogd
3.55 and 20's
Purchased new with 3:55 electronic locker & LT265/70R17, may have been an optional setup.
My point was simply that running two lane in WA and OR the 3:55's are great staying around +/-1500 rpm, but on the four lanes with higher speeds my mileage suffers from the lower gearing. The 6.7L has plenty of power and likes to run around 1600 rpm.
Old Sep 28, 2013 | 11:46 AM
sdetweil's Avatar
sdetweil
yes.. I would LOVE 3.31 on my dually. running about 3mpg less with the 3.73's
gasman6674
Nov 17, 2017 09:55 AM
Humph
All Things Towing
Sep 19, 2017 08:08 PM
wojowojo16
2015 - 2020 F150
Dec 4, 2015 11:12 AM
Refrigeration Tech
Oct 11, 2014 06:57 AM
CTYankee
Massachusetts Chapter
Feb 15, 2012 09:15 PM
