Sponsored by: Auxito
Help
Old Sep 24, 2013 | 07:05 PM
lunsfordpatrick's Avatar
lunsfordpatrick
Help
I have a 1999 ford f150 234,000 it has never not cranked or given me any trouble. I went to start it. It cranked and for a second then shut down. I have read thru some posts and done some testing. Here is what I have found.
1- It has 40lbs of fuel pressure I don't know if it is enough.
2- will start on contact cleaner;
3- no codes
4- antitheft is flashing goes off when the key is installed.
Everything in my mind says fuel pump ( still original pump ) But want to be 100% sure is there anything else I should check?
Old Sep 24, 2013 | 10:19 PM
Bluegrass 7's Avatar
Bluegrass 7
Some common sense is in order here.
If you measure 40 psi fuel pressure the fuel pump has to be ok.
Yes, adding some combustible in the absence of normal fuel and the motor fires tells you the ignition is also present.
This leaves the PATS system.
Put your key in, turn to run but do not crank.
Leave it a few minutes in that state and watch the Theft light.
Does it flash a two digit code?
If yes tell us what you count.
It may be some other issue but start here.
Good luck.
Old Sep 25, 2013 | 08:25 AM
lunsfordpatrick
Good luck.
I will do that I found a manual for my truck is says my year model needs 55 psi of fuel pressure. Will check pats again but best I can rember theft light goes out and stays out.
Old Sep 26, 2013 | 11:33 AM
lunsfordpatrick
Checked no flashing for codes from anti theft light. Dropping tank for fuel pump. Unless any other checks need to be made.
parcher440
Oct 5, 2016 12:32 AM
Bkadds
1997 - 2003 F150
18
Feb 13, 2015 02:45 PM
robjs111
1997 - 2003 F150
Aug 19, 2010 09:30 PM
mx495
Sep 17, 2007 05:24 PM
dub8
1978 - 1996 Big Bronco
May 1, 2006 05:32 PM
