1978 - 1996 Big Bronco
got an ?
Old Apr 30, 2006 | 10:02 PM
dub8's Avatar
dub8
got an ?
what part holds the fuel presser when the eng off i thinking mine is losing presser
Old May 1, 2006 | 12:11 AM
greystreak92's Avatar
greystreak92
Nothing holds it. The system pressure should eventually leak down but if everything is sealed properly, it takes a day or more to reach absolute zero pressure. The pump primes the system when the key is turned to the "ON" position to compensate for any leak-down since the last time the truck was run. I am making a rather broad assumption that the truck in question is fuel injected.
Old May 1, 2006 | 10:22 AM
nv_brewer's Avatar
nv_brewer
If your pressure bleeds off almost immediately, it's most likely your fuel pump. If that's the case the engine may be difficult to start after setting for awhile. I had to crank mine two to three times to start. After changing the FP everything worked fine.
Here's what I did to prove my fuel pump was bad:
1) Turn the key to 'RUN' (Don't start) Let the fuel pump run until it stops.
2) Turn key to 'OFF'
3) Repeat step 1 and 2
4) Repeat Step 1
5) Start engine.
If your FP is weak it will take a few runs to build the needed pressure.
Old May 1, 2006 | 05:20 PM
dub8's Avatar
dub8
could it be a bad presser reg.
Old May 1, 2006 | 05:32 PM
nv_brewer's Avatar
nv_brewer
It may also be bad but I doubt it's responsible for maintaining rail since it's job is to regulate the pressure flowing the other direction. As for mine, once I replaced my pump, the regulator showed twice the nomal pressure so it had to be replaced as well.
