E40d transmission problems
Old Sep 24, 2013 | 12:50 AM
801anderson's Avatar
801anderson
1994 F250 460ci E40d 4 wheel drive shifting first and second just fine. occasionally tries to shift to third but never follows through the shift ive gone through and dropped the trans fluid and pan, changed filter. nothing in the bottom of pan filter was a little dirty but after i changed the fluid and filter probelem is still there. anyone have any idea what might be goin on with it?
Old Sep 24, 2013 | 07:01 AM
rla2005's Avatar
rla2005
The E4OD transmission is 100% electronic controlled, check for codes by running the Key On Engine Off (KEOE) tests and Continuous Memory (CM) display.
Old Sep 24, 2013 | 08:55 AM
subford's Avatar
subford
Sounds like it is going into limp mode. Maybe a bad plug/wiring on the passenger side plug at the transmission.
Old Sep 24, 2013 | 11:50 AM
Lead Head's Avatar
Lead Head
Is your speedometer working correctly? If so, I think your MLPS (manual lever position sensor) on the side of the transmission may need adjustment, or your shifter indicator is no longer reading correctly and it's actually in "2" instead of "D".
Old Sep 24, 2013 | 01:13 PM
801anderson
speedo works and its in drive but i have been having problems (holding shift lever up to start it and holding it just right for reverse lights to come on when in reverse) before when it was just starting to do it i could push the overdrive off and it would shift but now its where it is now
Old Sep 24, 2013 | 01:25 PM
Lead Head's Avatar
Lead Head
I suspect your transmission might actually be in "2nd". When driving, try pushing the shifter more towards neutral, and seeing if it actually shifts.
Old Sep 24, 2013 | 01:35 PM
801anderson
went around the block and tried, it didnt make any difference
Old Sep 24, 2013 | 03:35 PM
raystankewitz's Avatar
raystankewitz
My 0.02 USD worth . . .
Pull the codes and post them up here.
My truck was doing a similar thing, turned out to be a bad 2nd gear solenoid. I changed the solenoid pack because that's what the codes pointed to, it's fine now.
HTH,
Ray
Old May 24, 2023 | 02:08 PM
JasonTaos's Avatar
JasonTaos
3rd Gear
My 1997 7.3 will not shift out of 1st. I have to manually shift it and then back. Not sure what is going on. Suggestions?
Old May 24, 2023 | 02:13 PM
Lead Head's Avatar
Lead Head
First, pull the codes.
Second, make sure the speedometer is working.
If it all checks out good, it's possible the intermediate clutch in the transmission is burnt out. When you apply manual second, the intermediate band also applies, which could mask a burnt out intermediate clutch.
f100guy
62
Feb 2, 2026 04:15 PM
DAAJR
19
Nov 9, 2009 06:17 PM
t4kne
Mar 24, 2008 04:22 PM
freakgt427
Jun 11, 2005 10:26 AM
