Automatic trans: shifting problems
Old Mar 23, 2008 | 11:40 AM
t4kne's Avatar
t4kne
93 F150 4X4, 300cu, Automatic, everything stock. Sometimes my truck wants to stay in first gear. Sticks there even when I'm at 20 mhp. I let off the gas and it shifts to second. Sometimes when shifting from second to third, it shifts into nothing, like it's in neutral. I'm driving along and the engine revs but no shift. When this happeneds, I can manually shift it into second and it drops right back into second no problem. Drive for a second or two and then manually shift it into "D", it shifts into 3rd just fine. Has even slipped out of third once or twice. Sometimes it all works fine. Fluid level is ok. I put new fluid and filter in it last year around this time. Anyone have an idea? Seems to happen more often when its a cold day, say in the teens. Thanks for you help.
Tim
Old Mar 23, 2008 | 12:45 PM
quicklook2's Avatar
quicklook2
unless you drained the convertor then you need to do the filter pan and convertor drain to replace all the old fluid.
look at the mlps switch on the trans also.
Old Mar 23, 2008 | 05:40 PM
t4kne's Avatar
t4kne
Thanks for the feedback. I did not drain the converter, just dropped the pan, replaced the filter and maybe 5 quarts of fluid. where abouts is the mlps switch? What is it's function? Thanks.
Old Mar 23, 2008 | 06:42 PM
quicklook2's Avatar
quicklook2
it is on the side of the trans.
manual lever position switch = mlps
Old Mar 23, 2008 | 08:59 PM
t4kne's Avatar
t4kne
Oh,OK, I know what that is. I replaced that last year for a neutral safety switch problem. You still think that could be it? Just inspect it to see if it is in tact?
Old Mar 24, 2008 | 04:22 PM
fast70's Avatar
fast70
change it again that sounds like your problem
