Ugh more problems:(
Old Sep 24, 2013 | 09:13 PM
dylansf23's Avatar
dylansf23
Great aha, should I be concerned about the brake light coming on on hard pushes? Or just flush the fluid and be good?
fordfan32's Avatar
fordfan32
What year and engine is the truck? Oil out the valve cover breather can mean high crankcase pressure. This means blow-by. In New engines it can mean you have some ring gaps lined up. In old engines it can simply mean they are on their last legs. The light means low brake fluid. And as mentioned it doesn't evaporate its going somewhere. Also it is hydroscopic meaning it absorbs moisture and deteriorates. Flush the brakes and you likely need a rear brake cylinder. Pull your drums to see. If your in there do the shoes too. They will likely be soaked in the oil.
Old Sep 24, 2013 | 09:17 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Flush the fluid.
It may take more than one quart to get clear fresh fluid to all 4 corners.
You say the light only comes on if you really stand on the brakes?
Old Sep 24, 2013 | 09:31 PM
fordfan32's Avatar
fordfan32
The brake light is also tied in with abs sensor on rear axle from about 87 to the 90's some time. So I ask Hard brake applications where you lock the wheels?
Old Sep 24, 2013 | 09:37 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
like Gary said it's just a pressure differential shuttle.
If it comes on and stays on it needs to be reset.
From what is described I would look for a rubber line ballooning since there doesn't seem to be air in the system.
Old Sep 25, 2013 | 05:23 PM
dylansf23's Avatar
dylansf23
Okay it's an 85 with the feedback carb on a i6
I'm going to change the valve cover gasket tomorrow and see if that helps with my oil leak any.
I looked at my lines and they are all good, steel lines no kinks or bubbles.
I adjusted my parking brake and I will test if that helped my brakes at all. They were acting god this morning but as the day went on they got worse and worse. (About three or four twenty minutes drives, not much mileage at 35mph)
Anything I should look for as far as the valves go? Also where could I look to see if it is a rear main? From the valve cover back it's all oil covered. It blew out the breather on the highway. I'm going to wash it as best as I can tonight.
Old Sep 25, 2013 | 07:02 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If it's blowing out the breather at sustained high rev's I would do a leakdown or at least compression test all 6 cylinders.
That doesn't sound good.
As far as the brakes.
Adjust the drums and see how much that helps.
Does the pedal stay high and firm if you hold pressure with the engine off?
If you've bled the brakes and checked the lines, the master cylinder may be leaking internally.
Old Sep 25, 2013 | 08:24 PM
dylansf23's Avatar
dylansf23
Tightened the drums and it stops now, I didn't see a light, but I'm used to the disks stopping it and te drums are stopping it now, almost feels like I have a trailer. I washed the engine alot today and I'm going to see if I can spot any an all leaks tomorrow after I drive it.
Old Sep 25, 2013 | 08:30 PM
Gary Lewis's Avatar
Gary Lewis
They make an additive you put in the oil that lets you see where the leaks are by using a black/UV light.
Old Sep 25, 2013 | 09:20 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I have the flashlight and glasses, but you have to find it before it spreads everywhere.
thatsrealnice
Sep 27, 2011 06:35 AM
NC2X4
15
Aug 31, 2010 10:48 PM
aph453
Jan 29, 2005 11:04 AM
Shadowe
Jan 14, 2005 06:10 PM
bIIcool
Bronco II
Oct 28, 2004 07:35 PM
