Hey guys I'm in the process of installing 03 tow mirrors with heart, signal, and running light. I read other install procedures but all they say is to hook the signals to the steering column at the signal switch but no pictures or anything. I cant seem to find where the wires are and where the easiest spot to tie into them? Please any help is greatly appreciated!
Go to the Excursion forum and click on the tech folder sticky. Scroll down to the Exterior body section and click on the '08 mirror install link. I believe the thread show you how to wire up for lights and blinkers.
Thank you for the help! The only question i have is that i have an 01 and the write up said to pull the plug from the fuse panel now is that the same for my 01 f250?
Edit: i actually have the running lights hooked up already i just need to do the blinkers but I'm not really sure where the best spot to tie into the wiring is? I believe i found the correct worrying i will need to confirm tomorrow with a meter.
