Stalling when accelerating.
Old Sep 23, 2013 | 09:17 AM
aedinius's Avatar
aedinius
Trailering
My 78 F100 has a new motor (302W V8) and transmission (C4, 3speed auto), and they have about 400 miles on them (by my clock, I'm not sure how much the mechanic drove it before I picked it up).
Especially when the weather is cool out (evenings, mornings, etc), the vehicle would hesitate when I pressed on the gas pedal. I rationalized this as a downshift, since I was usually rolling.
This morning, I started it up and let it warm up for about 5 minutes, then when I put it in gear and started to take off, it stalled. I put it in neutral, started it again, and then drove off just fine. I got to the stop light, and the same thing happened. I put it in neutral, started it again, and it drove off just fine.
When I stopped for gas, I checked the transmission fluid and noticed the dipstick wasn't fully seated into the ... dipstick... holder thingy. Could this be related?
Old Sep 23, 2013 | 10:38 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Dipstick "thingy" doesn't have anything to do with your problem.
Problems like this are hard to diagnose by remote control.
My first impression would be it could be either fuel or ignition, you'll need to do some troubleshooting.
Check the distributor's vacuum advance, see if the advance is unit is good.
Pull the cap off and get a short piece of hose, put the hose on the advance and apply a vacuum source (suck on the end works) so if the advance plate moves. If it doesn't, replace the advance.
Check for any possible vacuum leaks. Check the initial timing. Check the fuel filter. Use a vacuum gauge to adjust the carb mixture (adjust for highest manifold vacuum), check the EGR valve, make sure the valve is good and is closing and not leaking.
FoPar1972
34
Sep 23, 2018 07:37 PM
FordmanShane
23
Aug 31, 2012 01:44 AM
linus72
Feb 10, 2012 06:03 PM
mwalt88
40
May 9, 2009 08:55 PM
oem78
Feb 10, 2006 11:48 AM
