Camber fixes?
Old Sep 22, 2013 | 10:50 PM
shane_lxi's Avatar
shane_lxi
Camber fixes?
I'm looking into suspension options and I'm trying to do as much research as I can. I've seen a few members with dream beams and cut springs with what looks like close to 0degrees of camber? I know you can bend factory forged beams for around +1.5degress, but how are people getting close to acceptable camber with non-bendable aftermarket beams and short springs? I've heard of an I-beam pivot hole mod that can help, but I haven't seen any pics or a detailed description of it yet. Any help is appreciated!!
Old Sep 22, 2013 | 11:09 PM
HIO Silver's Avatar
HIO Silver
Lowering beams simply change the relative position of the spindle mount and the I-beam's horizontal centerline. It's moved up three inches thus resulting in a three-inch drop. In theory, camber does not change. Caster doesn't either because the spindle mount is leaned back per the OEM specs.
I'm not aware of cut springs in addition to a beam drop. It's possible to do if stiffer front springs are used like from a 460-equipped vehicle. Eaton Detroit Spring (EATON Detroit Spring - The leading manufacturer of leaf and coil springs for the street rod and restoration industries) offers front lowering springs but like at the cost of ride quality due to a higher spring rate.
Here's is their fitment search page: Ordering - EATON Detroit Spring
What options are you considering? Prolly the most adjustable is a Mustang II-style IFS or a CVS subframe conversion.
Old Sep 22, 2013 | 11:25 PM
shane_lxi's Avatar
shane_lxi
Cutting the stock spring should bring spring rate up a bit also, which probably wouldn't necessarily be a bad thing on this boat, lol. I've looked into the cv swap also, but I'm not confident I can get the truck back in the road in a timely manner. Mostly concerned about fabbing motor mounts, steering column, and power steering pump brackets. But it's an option, definately the best performing option to boot, lol. The trucks I've seen with dream beams and 1.5-2 coils cut have the exact stance I'm looking for in the front. Can deal with a little negative camber, but I'd rather not deal with -3degrees more, lol.
Old Sep 23, 2013 | 01:22 PM
liquor crazy's Avatar
liquor crazy
after the install of the beams I had tons of positive camber. I mean tons. and I drove it around the yard thinking it needed to cycle the suspension.
so after that I started to cut coils. ended up being close to factory camber after cutting 2.5 coils off. and its about as low as I want for now. but I have a cv clip and rear axle if I decide to go lower or I can sell it and get a few bucks . so if you decide to do a cv and your near ohio hit me up
Diverdan0430
Mar 12, 2019 02:46 PM
PoreBoy
Apr 28, 2016 08:27 AM
2xcrash
Nov 15, 2012 02:07 PM
71fordkid
73
Apr 27, 2009 01:58 AM
71fordkid
Oct 12, 2007 09:44 AM
