surging ?
Old Sep 22, 2013 | 02:49 PM
bigbadwolfe's Avatar
bigbadwolfe
surging ?
i recently purchased 3 obs powerstroke superdutys that have been sitting in a barn in georgia for the last 13 years the flatbed is idi sorry but any ways that in not the problem the 95 that has 51000 miles on it is surging i have done the fuel pump and the fuel bowl and reg plus 6 injectors still has the same surging problem i am leaning to the hpop by the way the oil is coming out of the injectors with the valve covers off watching it run does this sound right to you my modded truck in my sig does the same thing when i am on it and it runs out if oil thats why i am saying the hpop is weak ant ideas ?
Old Sep 22, 2013 | 03:01 PM
Hussler's Avatar
Hussler
Do you have a scanner, that would help isolate the issue? If not and they have been sitting for 13 years ... yikes. I would suspect the ICP and you could just unplug it and see if the surging goes away, PCM will run on default values. Also the IPR o-rings could just be bad due to sitting for such a long time. My assumption is you did a oil change?
Old Sep 22, 2013 | 03:22 PM
bigbadwolfe
i did all the normal things to the truck that it needs after such a slumber including 2 oil changes and 3 fuel filters fuel tank screen fpr screen blew the lines out both ways i dont think it is a fuel issue at this point
Old Sep 22, 2013 | 04:01 PM
Hussler's Avatar
Hussler
I did not mention fuel pressure as an issue because you indicated the pump was replaced? I mentioned the possibility of ICP or IPR.
Old Sep 22, 2013 | 07:39 PM
bigbadwolfe
i ran it with the icp unpluged no difference
sklmod95
6.4L Power Stroke Diesel
May 31, 2018 07:31 AM
williameub
Aug 16, 2014 06:20 PM
valiant500hp
Jan 14, 2011 03:13 AM
Butch(OH)
May 5, 2009 09:59 AM
Lashlaroo
Oct 5, 2004 04:11 PM
