2000 ford excursion start problems?
Old Sep 21, 2013 | 04:25 PM
kylehoff123's Avatar
kylehoff123
Ok, so I posted a few weeks ago I had a 1 6 pats code.
I have a 2000 ford excursion V10 . When I turn the key I get a rapid flashing theft light. No check engine light or engine light. I have check all my fuses in the vehicle unless there are hidden ones. My code reader and my tuner says no connection. They do power up but it just can not link. I did jump the relay for my pcm. Then my pats light does its check and shuts off then I get my check engine light comes on and does not shut off. I did get one code the P1000 code and the vehicle still will not start. As soon as I put my realy back in the pcm it goes directly back to the way it was. So my thought is that my PCM is not powering on. What can cause this? any ideals?
Does anyone have anythoughts towards this. Anyone in or around Killeen tx that has a bybass tuner? I need some help because I don't have the money to take this to FORD.
Old Oct 6, 2013 | 04:39 PM
kylehoff123
BUMP? Anyone
Old Oct 6, 2013 | 06:07 PM
garryk6's Avatar
garryk6
I have 2 2000 excursions. Both have experienced the rapid "theft light" flash and no start. On one we had the ignition switch and PATS replaced to the tune of $500+. While the occurrence of the problem was less, it still happened. One of the service techs said that there was a problem with the 2000 year model only. And all you had to do was when the theft light flashes fast, turn the key back to off for a few seconds the back to on, and it should go through the normal sequence and start right up. So far that advice has proved good to go.
Garry
Old Oct 6, 2013 | 06:25 PM
kylehoff123
That used to work but it won't anymore I tried like 1000 times lol what parts did they have to replace ?
Old Oct 6, 2013 | 07:31 PM
projectSHO89's Avatar
projectSHO89
You've already confirmed that you have a PCM power problem. It's time to break out the meter and the schematic so that you can see what is wrong. It might be a relay, fuse, diode, fuse box, ignition switch, wiring connection, etc. The voltage readings will guide troubleshooting.
Old Oct 6, 2013 | 10:53 PM
garryk6's Avatar
garryk6
They replaced the Pats module and keys, and it only flashes occasionally. Appearantly they fixed the problem in the 2001 and on models.
Hopefully that helps.
Garry
Old Oct 6, 2013 | 11:19 PM
GermanMike's Avatar
GermanMike
Back when we bought our EX 3 years ago I had exact the same problem.
It turned out that the batterie was kind of shot. Strong enough to crank the engine, but something in the PCM was underpowered.
I changed it and since than, we never had ay issues with that again.
.....but to be honest, I never knew exactly what it was.....whatever.....shes reliable since than.
makuloco2000
Escape & Escape Hybrid
Oct 4, 2022 11:44 AM
Ravendaeth66
Jun 16, 2019 04:03 AM
willy j
1997 - 2003 F150
Jul 4, 2016 11:12 AM
TK71
Modular V10 (6.8l)
Sep 17, 2013 11:52 AM
seesaw_4
Jul 17, 2008 06:44 AM
